ArcGIS.Core.CIM Namespace / CIMClassBreak Class
Properties Methods Events
    CIMClassBreak Class Members
    The following tables list the members exposed by CIMClassBreak.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets an array of symbol references that are intended to be used at specific scale ranges.
    Public Property Gets or sets a value indicating whether or not this is a critical break.
    Public Property Gets or sets the custom patch for this class.
    Public Property Gets or sets the description.
    Public Property Gets or sets the label.
    Public Property Gets or sets the patch shape for this class.
    Public Property Gets or sets the symbol for the class.
    Public Property Gets or sets the upper bound of the class.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMClassBreak.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMClassBreak with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMClassBreak and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
