ArcGIS.Core.CIM Namespace / CIMAviationArrow Class
Properties Methods Events
    CIMAviationArrow Class Members
    The following tables list the members exposed by CIMAviationArrow.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the line length for the arrow, internally units will always be of type points.
    Public Property Gets or sets the default point symbol for the arrow.
    Public Property Gets or sets a value indicating whether the arrow is enabled.
    Public Property Gets or sets a value indicating whether the arrow's line indicator is enabled.
    Public Property Gets or sets the text for the line indicator text symbol.
    Public Property Gets or sets the indicator text symbol for the arrow.
    Public Property Gets or sets the line symbol for the arrow.
    Public Property Gets or sets the negative point symbol for the arrow.
    Public Property Gets or sets the positive point symbol for the arrow.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMAviationArrow.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMAviationArrow with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMAviationArrow and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
