ArcGIS.Core.Geometry Namespace / MapPointBuilderEx Class / CreateMapPoint Method / CreateMapPoint(Double,Double,Double,Double,Int32,SpatialReference) Method
X coordinate.
Y coordinate.
Z coordinate. HasZ is set to true.
Measure value. HasM is set to true.
ID value. HasID is set to true.
(Optional) The SpatialReference. The default value is null.
Example
    Convenience method to create a MapPoint instance with the given X, Y, Z, M and ID coordinates. The HasZ, HasM and HasID properties on this instance are set to true.
    Syntax
    public static MapPoint CreateMapPoint(
       double x,
       double y,
       double z,
       double m,
       int id,
       SpatialReference spatialReference
    Public Overloads Shared Function CreateMapPoint( _
       ByVal x As Double, _
       ByVal y As Double, _
       ByVal z As Double, _
       ByVal m As Double, _
       ByVal id As Integer, _
       Optional ByVal spatialReference As SpatialReference _
    ) As MapPoint
    Parameters
    x
    X coordinate.
    y
    Y coordinate.
    z
    m
    id
    spatialReference
    Return Value
    Example
    Builder Properties
      // list of points
      List<MapPoint> pointsForBuilder = new List<MapPoint>
      MapPointBuilderEx.CreateMapPoint(0, 0, 2, 3, 1),
      MapPointBuilderEx.CreateMapPoint(1, 1, 5, 6),
      MapPointBuilderEx.CreateMapPoint(2, 1, 6),
      MapPointBuilderEx.CreateMapPoint(0, 0)
      // will have attributes because it is created with convenience method
      Polyline polylineWithAttrs = PolylineBuilderEx.CreatePolyline(pointsForBuilder);
      bool hasZ = polylineWithAttrs.HasZ;          // hasZ = true
      bool hasM = polylineWithAttrs.HasM;          // hasM = true
      bool hasID = polylineWithAttrs.HasID;        // hasID = true
      // will not have attributes because it is specified as a parameter
      Polyline polylineWithoutAttrs =
        PolylineBuilderEx.CreatePolyline(pointsForBuilder, AttributeFlags.None);
      hasZ = polylineWithoutAttrs.HasZ;          // hasZ = false
      hasM = polylineWithoutAttrs.HasM;          // hasM = false
      hasID = polylineWithoutAttrs.HasID;        // hasID = false
      Polygon polygonWithAttrs = PolygonBuilderEx.CreatePolygon(pointsForBuilder);
      hasZ = polygonWithAttrs.HasZ;               // hasZ = true
      hasM = polygonWithAttrs.HasM;               // hasM = true
      hasID = polygonWithAttrs.HasID;             // hasID = true
      Polygon polygonWithoutAttrs =
            PolygonBuilderEx.CreatePolygon(pointsForBuilder, AttributeFlags.None);
      hasZ = polygonWithoutAttrs.HasZ;               // hasZ = false
      hasM = polygonWithoutAttrs.HasM;               // hasM = false
      hasID = polygonWithoutAttrs.HasID;             // hasID = false
      PolylineBuilderEx polylineB =
                 new PolylineBuilderEx(pointsForBuilder, AttributeFlags.None);
      hasZ = polylineB.HasZ;                      // hasZ = false
      hasM = polylineB.HasM;                      // hasM = false
      hasID = polylineB.HasID;                    // hasID = false
      // will have attributes because it is passed an attributed polyline
      polylineB = new PolylineBuilderEx(polylineWithAttrs);
      hasZ = polylineB.HasZ;                      // hasZ = true
      hasM = polylineB.HasM;                      // hasM = true
      hasID = polylineB.HasID;                    // hasID = true
      // will not have attributes because it is passed a non-attributed polyline
      polylineB = new PolylineBuilderEx(polylineWithoutAttrs);
      PolygonBuilderEx polygonB = new PolygonBuilderEx(pointsForBuilder, AttributeFlags.None);
      hasZ = polygonB.HasZ;                       // hasZ = false
      hasM = polygonB.HasM;                       // hasM = false
      hasID = polygonB.HasID;                     // hasID = false
      // will have attributes because it is passed an attributed polygon
      polygonB = new PolygonBuilderEx(polygonWithAttrs);
      hasZ = polygonB.HasZ;                       // hasZ = true
      hasM = polygonB.HasM;                       // hasM = true
      hasID = polygonB.HasID;                     // hasID = true
      // will not have attributes because it is passed a non-attributed polygon
      polygonB = new PolygonBuilderEx(polygonWithoutAttrs);
    Construct a MapPoint
      // Use a builder convenience method or use a builder constructor.
      // Create a 2D point without a spatial reference
      MapPoint point2D = MapPointBuilderEx.CreateMapPoint(1, 2);
      SpatialReference sr = point2D.SpatialReference; // sr = null
      bool hasZ = point2D.HasZ;   // hasZ = false
      bool hasM = point2D.HasM;   // hasM = false
      bool hasID = point2D.HasID; // hasID = false
      double x = point2D.X;   // x = 1
      double y = point2D.Y;   // y = 2
      double z = point2D.Z;   // z = 0 default value
      double m = point2D.M;   // m is NaN default value
      double id = point2D.ID; // id = 0 default value
      // Or use a builderEx which doesn't need to run on the MCT.
      MapPointBuilderEx builderEx = new MapPointBuilderEx(1, 2);
      // do something with the builder
      builderEx.Y = 3;
      point2D = builderEx.ToGeometry();
      y = point2D.Y;   // y = 3
      // Create a 2D point with a spatial reference
      SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(4269);
      point2D = MapPointBuilderEx.CreateMapPoint(1, 2, spatialReference);
      sr = point2D.SpatialReference; // sr != null
      int wkid = sr.Wkid; // wkid = 4269
      // Or use a builder
      builderEx = new MapPointBuilderEx(1, 2, spatialReference);
      // Do something with the builder
      builderEx.SetValues(3, 5);
      x = point2D.X; // x = 3
      y = point2D.Y; // y = 5
      // Change the spatial reference of the builder
      builderEx.SpatialReference = SpatialReferences.WGS84;
      wkid = sr.Wkid; // wkid = 4326
      // Create a 3D point with M
      MapPoint pointZM = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4);
      sr = pointZM.SpatialReference; // sr = null
      hasZ = pointZM.HasZ;   // hasZ = true
      hasM = pointZM.HasM;   // hasM = true
      hasID = pointZM.HasID; // hasID = false
      x = pointZM.X;   // x = 1
      y = pointZM.Y;   // y = 2
      z = pointZM.Z;   // z = 3
      m = pointZM.M;   // m = 4
      id = pointZM.ID; // id = 0 default value
      // Create a 3D point with M and a spatial reference
      pointZM = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, spatialReference);
      sr = pointZM.SpatialReference; // sr != null
      // Create a point from another point in three ways
      MapPoint clone = pointZM.Clone() as MapPoint; // Has the same values including the spatial reference as pointZM
      MapPoint anotherZM = MapPointBuilderEx.CreateMapPoint(pointZM);  // Has the same values including the spatial reference as pointZM
      builderEx = new MapPointBuilderEx(pointZM); // Has the same values including the spatial reference as pointZM
      builderEx.HasM = false;
      builderEx.ID = 7; // Setting the id also sets HasID = true
      MapPoint pointZId = builderEx.ToGeometry();
      sr = pointZId.SpatialReference; // sr != null
      hasZ = pointZId.HasZ;   // hasZ = true
      hasM = pointZId.HasM;   // hasM = false
      hasID = pointZId.HasID; // hasID = true
      x = pointZId.X;   // x = 1
      y = pointZId.Y;   // y = 2
      z = pointZId.Z;   // z = 3
      m = pointZId.M;   // m is NaN, default value
      id = pointZId.ID; // id = 7
      // Create a point with Z, M, and ID-values
      MapPoint pointZMId = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, 5, spatialReference);
      sr = pointZMId.SpatialReference; // sr != null
      hasZ = pointZMId.HasZ;   // hasZ = true
      hasM = pointZMId.HasM;   // hasM = true
      hasID = pointZMId.HasID; // hasID = true
      x = pointZMId.X;   // x = 1
      y = pointZMId.Y;   // y = 2
      z = pointZMId.Z;   // z = 3
      m = pointZMId.M;   // m = 4
      id = pointZMId.ID; // id = 5
      // Pick and choose which attributes to include
      MapPoint point = MapPointBuilderEx.CreateMapPoint(1, 2, false, 3, true, 4, true, 5);
      sr = point.SpatialReference; // sr = null
      hasZ = point.HasZ;   // hasZ = false
      hasM = point.HasM;   // hasM = true
      hasID = point.HasID; // hasID = true
      x = point.X;   // x = 1
      y = point.Y;   // y = 2
      z = point.Z;   // z = 0, default value
      m = point.M;   // m = 4
      id = point.ID; // id = 5
      // Or use a builder
      builderEx = new(1, 2, true, 3, false, 4, true, 5);
      builderEx.ID = 7;
      point = builderEx.ToGeometry();
      sr = point.SpatialReference; // sr != null
      hasZ = point.HasZ;   // hasZ = true
      hasM = point.HasM;   // hasM = false
      m = point.M;   // m is NaN, default value
      id = point.ID; // id = 7
    MapPoint IsEqual
      MapPoint pt1 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, 5);
      int ID = pt1.ID;           // ID = 5
      bool hasID = pt1.HasID;     // hasID = true
      MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, 0);
      ID = pt2.ID;        // ID = 0
      hasID = pt2.HasID;  // hasID = true
      MapPoint pt3 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4);
      ID = pt3.ID;          // ID = 0
      hasID = pt3.HasID;    // hasID = false
      MapPoint pt4 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 44);
      ID = pt4.ID;          // ID = 0
      hasID = pt4.HasID;    // hasID = false
      bool hasM = pt4.HasM; // hasM = true
      MapPoint pt5 = MapPointBuilderEx.CreateMapPoint(1, 2, 3);
      ID = pt5.ID;          // ID = 0
      hasID = pt5.HasID;    // hasID = false
      hasM = pt5.HasM;      // hasM = false
      bool isEqual = pt1.IsEqual(pt2);   // isEqual = false, different IDs
      isEqual = pt2.IsEqual(pt3);        // isEqual = false, HasId is different
      isEqual = pt4.IsEqual(pt3);        // isEqual = false, different Ms
      isEqual = pt1.IsEqual(pt5);        // isEqual = false, pt has M, id but pt5 does not.
    Import and Export Geometries to XML
      MapPoint minPoint = MapPointBuilderEx.CreateMapPoint(1, 1, 1, 1, 3);
      MapPoint maxPoint = MapPointBuilderEx.CreateMapPoint(5, 5, 5);
      //  MapPoint
      string xml = minPoint.ToXml();
      MapPoint minPointImport = MapPointBuilderEx.FromXml(xml);
      // minPointImport = minPoint
      // Envelope
      Envelope envelopeWithID = EnvelopeBuilderEx.CreateEnvelope(minPoint, maxPoint);
      // Envelopes don't have IDs
      // envelopeWithID.HasID = false
      // envelopeWithID.HasM = true
      // envelopeWithID.HasZ = true
      xml = envelopeWithID.ToXml();
      Envelope envelopeImport = EnvelopeBuilderEx.FromXml(xml);
      // Multipoint
      List<MapPoint> list = new List<MapPoint>();
      list.Add(minPoint);
      list.Add(maxPoint);
      Multipoint multiPoint = MultipointBuilderEx.CreateMultipoint(list);
      xml = multiPoint.ToXml();
      Multipoint multipointImport = MultipointBuilderEx.FromXml(xml);
      // multipointImport.PointCount == 2
      // multipointImport.HasID = true
      // multipointImport.HasM = true
      // multipointImport.HasZ= true
    Requirements
