ArcGIS.Core.Geometry Namespace / MultipointBuilderEx Class / CreateMultipoint Method / CreateMultipoint(Multipoint,SpatialReference) Method
The multipoint to copy.
(Optional) The spatial reference of the newly created multipoint. If it is null, then the spatial reference will be inherited from the input multipoint.
    Convenience method to create an instance of the Multipoint class.
    Syntax
    Public Overloads Shared Function CreateMultipoint( _
       ByVal multipoint As Multipoint, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Multipoint
    Parameters
    multipoint
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    multipoint is null.
    Remarks
    The newly created multipoint inherits the HasZ, HasM, HasID attributes and the corresponding Z, M, ID values from the input multipoint.The newly created multipoint inherits the HasZ, HasM, HasID attributes and the corresponding Z, M, ID values from the input multipoint.
    Requirements
