ArcGIS.Core.Geometry Namespace / MultipointBuilderEx Class / CreateMultipoint Method / CreateMultipoint(IEnumerable<MapPoint>,AttributeFlags,SpatialReference) Method
The points of the newly created multipoint.
AttributeFlags to set the HasZ, HasM and HasID properties. If no attributes should be set, pass AttributeFlags.None. If all attributes should be set, pass AttributeFlags.AllAttributes. Use the bitwise OR operator to set two attributes. For example, to set HasZ = true and HasM = true, pass AttributeFlags.HasZ | AttributeFlags.HasM. For performance reasons, the attributes of the input points are not used. However, if an attribute is specified, then the attribute values of the input points is used. For example, if AttributeFlags.HasZ is specified, then the Z-values of the input points is used for the newly created multipoint.
(Optional) The spatial reference of the newly created multipoint. The default value is null. For performance reasons, the spatial references of the input points are not checked nor are they used. To avoid undefined behavior, make sure that the spatial references of the input points are compatible or null.
Example
    Convenience method to create an instance of the Multipoint class.
    Syntax
    Public Overloads Shared Function CreateMultipoint( _
       ByVal points As IEnumerable(Of MapPoint), _
       ByVal attributes As AttributeFlags, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Multipoint
    Parameters
    points
    attributes
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    points is null.
    Example
    Construct a Multipoint - from an enumeration of MapPoints
      // Use a builderEx convenience method or use a builderEx constructor.
      List<MapPoint> list = new List<MapPoint>();
      list.Add(MapPointBuilderEx.CreateMapPoint(1.0, 1.0));
      list.Add(MapPointBuilderEx.CreateMapPoint(1.0, 2.0));
      list.Add(MapPointBuilderEx.CreateMapPoint(2.0, 2.0));
      list.Add(MapPointBuilderEx.CreateMapPoint(2.0, 1.0));
      // use the builderEx constructors which don't need to run on the MCT.
      // use AttributeFlags.NoAttributes since we have 2d points in the list
      MultipointBuilderEx builderEx = new MultipointBuilderEx(list, AttributeFlags.None);
      Multipoint multiPoint = builderEx.ToGeometry() as Multipoint;
      int ptCount = builderEx.PointCount;
      // builderEx convenience methods don't need to run on the MCT
      multiPoint = MultipointBuilderEx.CreateMultipoint(list);
      // multiPoint.HasZ, HasM, HasID will be false - the attributes are determined
      //    based on the attribute state of the points in the list
      // or specifically set the state
      multiPoint = MultipointBuilderEx.CreateMultipoint(list, AttributeFlags.None);
      // multiPoint.HasM = false
      multiPoint = MultipointBuilderEx.CreateMultipoint(list, AttributeFlags.HasM);
      // multiPoint.HasM = true
      ptCount = multiPoint.PointCount;
    Requirements
