ArcGIS.Desktop.Core Namespace / FavoritesManager Class / AddFavorite Method / AddFavorite(Item) Method
The item to add to the favorite collection. For example a folder connection or a toolbox.
Example
    Adds an item to the favorites collection. The item is added to the collection with the Favorite.IsAddedToAllNewProjects value set to false.
    Syntax
    public Favorite AddFavorite(
       Item item
    Public Overloads Function AddFavorite( _
       ByVal item As Item _
    ) As Favorite
    Parameters
    item
    Return Value
    The favorite item. Null if the item cannot be added as a favorite.
    Remarks
    An item can only exist once in the favorite collection. If the item already exists in the favorites collection, then no additional item is added. However the Favorite.IsAddedToAllNewProjects property will be updated to false.
    You should always check CanAddAsFavorite before passing an item to this method.
    Example
    Add a Favorite - Folder
      var itemFolder = ItemFactory.Instance.Create(@"d:\data");
      // is the folder item already a favorite?
      var fav = FavoritesManager.Current.GetFavorite(itemFolder);
      if (fav == null)
        if (FavoritesManager.Current.CanAddAsFavorite(itemFolder))
          fav = FavoritesManager.Current.AddFavorite(itemFolder);
    Add a Favorite - Style project item
      StyleProjectItem styleItem = Project.Current.GetItems<StyleProjectItem>().
                              FirstOrDefault(style => style.Name == "ArcGIS 3D");
      if (FavoritesManager.Current.CanAddAsFavorite(styleItem))
        // add to favorites with IsAddedToAllNewProjects set to false
        FavoritesManager.Current.AddFavorite(styleItem);
    Requirements
