ArcGIS.Desktop.Core Namespace / FavoritesManager Class / InsertFavorite Method / InsertFavorite(Item,Int32,Boolean) Method
The item to add to the favorite collection. For example a folder connection or a toolbox.
The index at which the item is to be inserted.
Is the new favorite to be added to all new projects.
Example
    Inserts an item to the favorites collection.
    Syntax
    Public Overloads Function InsertFavorite( _
       ByVal item As Item, _
       ByVal index As Integer, _
       ByVal addToAllNewProjects As Boolean _
    ) As Favorite
    public Favorite InsertFavorite(
       Item item,
       int index,
       bool addToAllNewProjects
    Parameters
    item
    index
    addToAllNewProjects
    Return Value
    The favorite item. Null if the item cannot be added as a favorite.
    Remarks
    An item can only exist once in the favorite collection. If the item already exists in the favorites collection, then no additional item is inserted. However the existing item will be moved to the specified index and the Favorite.IsAddedToAllNewProjects property will be updated.
    You should always check CanAddAsFavorite before passing an item to this method.
    Example
    Insert a Favorite - Geodatabase path
      gdbPath = "@C:\\myDataFolder\\myData.gdb";
      var itemGDB = ItemFactory.Instance.Create(gdbPath);
      // is the item already a favorite?
      var favorite = FavoritesManager.Current.GetFavorite(itemGDB);
      // no; add it with IsAddedToAllNewProjects set to true
      if (favorite != null)
        if (FavoritesManager.Current.CanAddAsFavorite(itemGDB))
          FavoritesManager.Current.InsertFavorite(itemGDB, 1, true);
    Requirements
