ArcGIS.Core.Data Namespace / Feature Class / Item Property / Item(Int32) Property
The index of the field.
    Gets and sets the value of a field given its index position. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public override object Item(
       int index
    ) {get; set;}
    Public Overloads Overrides Property Item( _
       ByVal index As Integer _
    ) As Object
    Parameters
    index
    Property Value
    The value of the field.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    index corresponds to a shape field index and the type of shape (i.e., geometry) is not supported.
    Remarks
    The index for the fields is zero based. If the Field.FieldType corresponding to the specified field index is FieldType.Blob, the value will be System.IO.MemoryStream.
    Requirements
