ArcGIS.Core.Geometry Namespace / CubicBezierBuilderEx Class / CubicBezierBuilderEx Constructor / CubicBezierBuilderEx Constructor(IEnumerable<MapPoint>,SpatialReference)
The enumeration of points from which the curve will be constructed. Four points must be supplied.
(Optional) The spatial reference. The default value is null. The spatial references of the input points are ignored.
    Creates a new instance of the CubicBezierBuilderEx class from a set of points. Four points must be supplied.
    Syntax
    Public Function New( _
       ByVal points As IEnumerable(Of MapPoint), _
       Optional ByVal spatialReference As SpatialReference _
    Parameters
    points
    spatialReference
    Exceptions
    ExceptionDescription
    Four points are required for a cubic bezier.
    points is null or one of the 4 points is null or empty.
    Remarks
    The four points of the cubic bezier segment. points[0] is the start point, points[1] and points[2] are the control points, and points[3] is the end point.
    Requirements
