ArcGIS.Core.Geometry Namespace / PolygonBuilderEx Class / CreatePolygon Method / CreatePolygon(IEnumerable<Coordinate2D>,SpatialReference) Method
Coordinates to create the polygon. Line segments are created from the coordinates.
(Optional) The SpatialReference. The default value is null.
Example
    Convenience method to create a new instance of the Polygon class.
    Syntax
    Public Overloads Shared Function CreatePolygon( _
       ByVal coordinate2Ds As IEnumerable(Of Coordinate2D), _
       Optional ByVal spatialReference As SpatialReference _
    ) As Polygon
    Parameters
    coordinate2Ds
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    coordinate2Ds is null.
    Example
    Create an N-sided regular polygon
      // <summary>
      // Create an N-sided regular polygon.  A regular sided polygon is a polygon that is equiangular (all angles are equal in measure)
      // and equilateral (all sides are equal in length).  See https://en.wikipedia.org/wiki/Regular_polygon
      // </summary>
      // <param name="numSides">The number of sides in the polygon.</param>
      // <param name="center">The center of the polygon.</param>
      // <param name="radius">The distance from the center of the polygon to a vertex.</param>
      // <param name="rotation">The rotation angle in radians of the start point of the polygon. The start point will be
      // rotated counterclockwise from the positive x-axis.</param>
      // <returns>N-sided regular polygon.</returns>
      // <exception cref="ArgumentException">Number of sides is less than 3.</exception>
      static Polygon CreateRegularPolygon(int numSides, Coordinate2D center, double radius, double rotation)
        if (numSides < 3)
          throw new ArgumentException();
        Coordinate2D[] coords = new Coordinate2D[numSides + 1];
        double centerX = center.X;
        double centerY = center.Y;
        double x = radius * Math.Cos(rotation) + centerX;
        double y = radius * Math.Sin(rotation) + centerY;
        Coordinate2D start = new Coordinate2D(x, y);
        coords[0] = start;
        double da = 2 * Math.PI / numSides;
        for (int i = 1; i < numSides; i++)
          x = radius * Math.Cos(i * da + rotation) + centerX;
          y = radius * Math.Sin(i * da + rotation) + centerY;
          coords[i] = new Coordinate2D(x, y);
        coords[numSides] = start;
        return PolygonBuilderEx.CreatePolygon(coords);
    Import and Export Geometries to JSON
      // MapPoint
      string inputString =
        "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}";
      Geometry geometryFromJson = GeometryEngine.Instance.ImportFromJson(
        JsonImportFlags.JsonImportDefaults, inputString);
      MapPoint importPoint = geometryFromJson as MapPoint;
      // importPoint = 1, 2
      // importPoint.SpatialReference.WKid = 4326
      // use the MapPointBuilderEx convenience method
      MapPoint importPoint2 = MapPointBuilderEx.FromJson(inputString);
      // importPoint2 = 1, 2
      // impointPoint2.SpatialReference.Wkid = 4326
      string outputString = GeometryEngine.Instance.ExportToJson(
        JsonExportFlags.JsonExportDefaults, importPoint);
      // outputString =
      //   "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}"
      string outputString2 = importPoint.ToJson();
      inputString =
        "{\"spatialReference\":{\"wkid\":4326},\"z\":3,\"m\":4,\"x\":1,\"y\":2}";
      importPoint = GeometryEngine.Instance.ImportFromJson(
        JsonImportFlags.JsonImportDefaults, inputString) as MapPoint;
      // importPoint.HasM = true
      // importPoint.HasZ = true
      // importPoint.X = 1
      // importPoint.Y = 2
      // importPoint.M = 4
      // importPoint.Z = 3
      // export to json - skip spatial reference
                    JsonExportFlags.JsonExportSkipCRS, importPoint);
      // outputString = "{\"x\":1,\"y\":2,\"z\":3,\"m\":4}"
      // export from mappoint, skipping the sr - same as GeometryEngine.Instance.ExportToJson w JsonExportFlags.JsonExportSkipCRS
      outputString2 = importPoint.ToJson(true);
      // Multipoint
      List<Coordinate2D> coords = new List<Coordinate2D>()
      new Coordinate2D(100, 200),
      new Coordinate2D(201, 300),
      new Coordinate2D(301, 400),
      new Coordinate2D(401, 500)
      Multipoint multipointFromCoords = MultipointBuilderEx.CreateMultipoint(
        coords, SpatialReferences.WebMercator);
      inputString =
        "{\"points\":[[100,200],[201,300],[301,400],[401,500]],\"spatialReference\":{\"wkid\":3857}}";
      Multipoint importMultipoint =
               JsonImportFlags.JsonImportDefaults, inputString) as Multipoint;
      // importMultipoint.IsEqual(multipoint) = true
      ReadOnlyPointCollection pointsFromMultipoint = importMultipoint.Points;
      // points.Count = 4
      // points[0] = 100, 200
      // points[1] = 201, 300
      // points[2] = 301, 400
      // points[3] = 401, 500
      // use the MultipointbuilderEx convenience method
      Multipoint importMultipoint2 = MultipointBuilderEx.FromJson(inputString);
      // importMultipoint2.IsEqual(multipoint) = true
      // export to json
                      JsonExportFlags.JsonExportDefaults, multipointFromCoords);
      // outputString = inputString
      // or use the multipoint itself
      outputString2 = multipointFromCoords.ToJson();
      // Polyline
      Polyline polylineFromCoords = PolylineBuilderEx.CreatePolyline(
      // export without the spatial reference
                              JsonExportFlags.JsonExportSkipCRS, polylineFromCoords);
      // import
      geometry = GeometryEngine.Instance.ImportFromJson(
                   JsonImportFlags.JsonImportDefaults, outputString);
      Polyline importPolyline = geometryFromJson as Polyline;
      // importPolyline.SpatialReference = null
      pointsFromMultipoint = importPolyline.Points;
      // points.Count = 4
      // use the polylineBuilderEx convenience method
      Polyline importPolyline2 = PolylineBuilderEx.FromJson(outputString);
      // importPolyline2 = importPolyline
      outputString2 = importPolyline2.ToJson();
      // outputString2 = outputString
      // Polygon
      Polygon polygonFromCoords = PolygonBuilderEx.CreatePolygon(
                                JsonExportFlags.JsonExportSkipCRS, polygonFromCoords);
      // import
      Polygon importPolygon = geometry as Polygon;
      // importPolygon.SpatialReference = null
      pointsFromMultipoint = importPolygon.Points;
      // points.Count = 5
      // polygonBuilderEx convenience method
      Polygon importPolyon2 = PolygonBuilderEx.FromJson(outputString);
      // importPolygon2 = importPolygon
      // export from the polygon
      outputString2 = importPolyon2.ToJson(true);
      // Empty polygon
      polygon = PolygonBuilderEx.CreatePolygon(SpatialReferences.WebMercator);
                                     JsonExportFlags.JsonExportDefaults, polygon);
      importPolygon = GeometryEngine.Instance.ImportFromJson(
                          JsonImportFlags.JsonImportDefaults, outputString) as Polygon;
      // importPolygon.IsEmpty = true
      // importPolygon.SpatialReference.Wkid = 3857
    Create Lasso Polygon, Freehand Element
      await QueuedTask.Run(() =>
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(1, 1));
      plyCoords.Add(new Coordinate2D(1.25, 2));
      plyCoords.Add(new Coordinate2D(1.5, 1.1));
      plyCoords.Add(new Coordinate2D(1.75, 2));
      plyCoords.Add(new Coordinate2D(2, 1.1));
      plyCoords.Add(new Coordinate2D(2.25, 2));
      plyCoords.Add(new Coordinate2D(2.5, 1.1));
      plyCoords.Add(new Coordinate2D(2.75, 2));
      plyCoords.Add(new Coordinate2D(3, 1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                  ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
               ColorFactory.Instance.RedRGB, SimpleFillStyle.ForwardDiagonal, outline);
      ElementFactory.Instance.CreateGraphicElement(
        layout, poly, polySym, "New Lasso");
    Create Polygon Element
      //Build geometry
      plyCoords.Add(new Coordinate2D(1, 7));
      plyCoords.Add(new Coordinate2D(2, 7));
      plyCoords.Add(new Coordinate2D(2, 6.7));
      plyCoords.Add(new Coordinate2D(3, 6.7));
      plyCoords.Add(new Coordinate2D(3, 6.1));
      plyCoords.Add(new Coordinate2D(1, 6.1));
        ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.DashDotDot);
        layout, poly, polySym, "New Polygon", false);
    Create Rectangle Paragraph Text Element 1
      //Create rectangle text with background and border symbology.
      //Build 2D polygon geometry
      plyCoords.Add(new Coordinate2D(3.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.1));
      plyCoords.Add(new Coordinate2D(3.5, 6.1));
      //Also notice how formatting tags are using within the text string.
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                        ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
      string text = "Some Text String that is really long and is " +
                    "<BOL>forced to wrap to other lines</BOL> so that " +
                    "we can see the effects." as String;
      GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
      //(Optionally) Modify paragraph border
      CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
      CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
      cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
      cimPolyTxtGra.Frame.BorderSymbol.Symbol =
                   SymbolFactory.Instance.ConstructLineSymbol(
                              ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
      polyTxtElm.SetGraphic(polyTxtGra);
    Buffer many different Geometry Types
        new Coordinate2D(1, 2), new Coordinate2D(3, 4), new Coordinate2D(4, 2),
        new Coordinate2D(5, 6), new Coordinate2D(7, 8), new Coordinate2D(8, 4),
        new Coordinate2D(9, 10), new Coordinate2D(11, 12), new Coordinate2D(12, 8),
        new Coordinate2D(10, 8), new Coordinate2D(12, 12), new Coordinate2D(14, 10)
      List<Geometry> manyGeometries =
        MapPointBuilderEx.CreateMapPoint(coords[9]),
        PolylineBuilderEx.CreatePolyline([coords[0], coords[1], coords[2]], SpatialReferences.WGS84),
        PolylineBuilderEx.CreatePolyline([coords[3], coords[4], coords[5]]),
        PolygonBuilderEx.CreatePolygon([coords[6], coords[7], coords[8]])
      Geometry manyGeomBuffer = GeometryEngine.Instance.Buffer(manyGeometries, 0.25);
    Find the centroid of geometries
      // simple polygon
      List<Coordinate2D> list2D =
        new Coordinate2D(0, 0),
        new Coordinate2D(0, 2),
        new Coordinate2D(2, 2),
        new Coordinate2D(2, 0),
      polygon = PolygonBuilderEx.CreatePolygon(list2D, SpatialReferences.WGS84);
      // verify it is simple
      bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polygon);
      // find the centroid
      MapPoint centroid = GeometryEngine.Instance.Centroid(polygon);
      // centroid.X = 1
      // centroid.Y = 1
      // map Point
      MapPoint pt1 = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, SpatialReferences.WGS84);
      MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(5, 2, double.NaN, 7);
      // pt1.HasZ = true
      // pt1.HasM = true
      centroid = GeometryEngine.Instance.Centroid(pt1);
      // centroid.HasZ = true
      // centroid.HasM = true
      // pt1.IsEqual(centroid) = true
      // multipoint
      List<MapPoint> list = [pt1, pt2];
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(list);
      // multipoint.HasZ = true
      // multipoint.HasM = true
      centroid = GeometryEngine.Instance.Centroid(multipoint);
      // centroid.X = 3
      // centroid.Y = 2
      // centroid.HasZ = false
      // centroid.HasM = false
    Clip a Polyline by a Polygon
      // clip a polyline by a polygon
      List<Coordinate2D> list =
        new Coordinate2D(1.0, 1.0),
        new Coordinate2D(1.0, 4.0),
        new Coordinate2D(4.0, 4.0),
        new Coordinate2D(4.0, 1.0),
      polygon = PolygonBuilderEx.CreatePolygon(list, SpatialReferences.WGS84);
      LineSegment crossingLine = LineBuilderEx.CreateLineSegment(MapPointBuilderEx.CreateMapPoint(0, 3), MapPointBuilderEx.CreateMapPoint(5.0, 3.0));
      Polyline p = PolylineBuilderEx.CreatePolyline(crossingLine);
      Geometry geometry = GeometryEngine.Instance.Clip(p, polygon.Extent);
    Create a buffer polygon at the specified geodesic distance
        // buffer a point
        MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84);
        Polygon outPolygon = GeometryEngine.Instance.GeodesicBuffer(pt, 5) as Polygon;
        double delta = SpatialReferences.WGS84.XYTolerance * 2 * Math.Sqrt(2);
        ReadOnlyPointCollection points = outPolygon.Points;
        foreach (MapPoint p in points)
          double d = GeometryEngine.Instance.GeodesicDistance(pt, p);
          // d = 5 (+- delta)
        // specify a unit for the distance
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(pt, 5000, LinearUnit.Millimeters) as Polygon;
        // buffer of 0 distance produces an empty geometry
        Geometry g = GeometryEngine.Instance.GeodesicBuffer(pt, 0);
        // g.IsEmpty = true
        // buffer many points
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(10.0, 20.0),
      MapPointBuilderEx.CreateMapPoint(40.0, 40.0),
      MapPointBuilderEx.CreateMapPoint(60.0, 60.0),
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(list, 10000) as Polygon;
        // outPolygon.PartCount = 4
        // buffer different geometry types
          new Coordinate2D(1, 2), new Coordinate2D(10, 20), new Coordinate2D(20, 30),
      new Coordinate2D(50, 60), new Coordinate2D(70, 80), new Coordinate2D(80, 40),
      new Coordinate2D(90, 10), new Coordinate2D(110, 15), new Coordinate2D(120, 30),
      new Coordinate2D(10, 40), new Coordinate2D(-10, 40), new Coordinate2D(-10, 50)
      PolygonBuilderEx.CreatePolygon([coords[9], coords[10], coords[11]])
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(manyGeometries, 20000) as Polygon;
        // specify unit types
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(manyGeometries, 20, LinearUnit.Miles) as Polygon;
    GeodeticDensifyByLength - polygon
        new Coordinate2D(-80, 0),
    new Coordinate2D(-20, 60),
    new Coordinate2D(40, 20),
    new Coordinate2D(0, -20),
      SpatialReference sr = SpatialReferences.WGS84;
      // create a polygon
      polygon = PolygonBuilderEx.CreatePolygon(coords, sr);
      // get the geodesic lengths of the polygon segments
      ReadOnlySegmentCollection segments = polygon.Parts[0];
      List<double> geoLengths = new(segments.Count);
      foreach (Segment s in segments)
        Polyline line = PolylineBuilderEx.CreatePolyline(s, sr);
        double geoLen = GeometryEngine.Instance.GeodesicLength(line);
        geoLengths.Add(geoLen);
      // find the max length
      geoLengths.Sort();
      double maxLen = geoLengths[^1];
      // densify the polygon (in meters)
      Polygon densifiedPoly = GeometryEngine.Instance.GeodeticDensifyByLength(polygon, maxLen, LinearUnit.Meters, GeodeticCurveType.Geodesic) as Polygon;
      // densify the polygon (in km)
      double maxSegmentLength = maxLen / 10000;
      densifiedPoly = GeometryEngine.Instance.GeodeticDensifyByLength(polygon, maxSegmentLength, LinearUnit.Kilometers, GeodeticCurveType.Geodesic) as Polygon;
    Determine label point for a Polygon
      // create a polygon
        new Coordinate2D(1.0, 2.0),
        new Coordinate2D(2.0, 2.0),
        new Coordinate2D(2.0, 1.0),
      polygon = PolygonBuilderEx.CreatePolygon(list2D);
      MapPoint pt = GeometryEngine.Instance.LabelPoint(polygon);
    Separate components of a geometry into single component geometries
      List<Coordinate2D> coords2D =
      new Coordinate2D(1, 4),
      new Coordinate2D(2, 7),
      new Coordinate2D(-10, 3)
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(coords2D, SpatialReferences.WGS84);
      IReadOnlyList<Geometry> result = GeometryEngine.Instance.MultipartToSinglePart(multipoint);
      // result.Count = 4,
      // 'explode' a multipart polygon
      result = GeometryEngine.Instance.MultipartToSinglePart(multipartPolygon);
      // create a bag of geometries
      polygon = PolygonBuilderEx.CreatePolygon(coords2D, SpatialReferences.WGS84);
      var bag = GeometryBagBuilderEx.CreateGeometryBag([multipoint, polygon]);
      // bag.PartCount = =2
      result = GeometryEngine.Instance.MultipartToSinglePart(bag);
      // result.Count == 2
      // result[0] is MultiPoint
      // result[1] is Polygon
    Nearest Point versus Nearest Vertex
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(5, 5, sr);
        new Coordinate2D(10, 1),
      new Coordinate2D(10, -4),
      new Coordinate2D(0, -4),
      new Coordinate2D(0, 1),
      polygon = PolygonBuilderEx.CreatePolygon(coords);
      // find the nearest point in the polygon geometry to the pt
      ProximityResult result = GeometryEngine.Instance.NearestPoint(polygon, pt);
      // result.Point = 5, 1
      // result.SegmentIndex = 3
      // result.PartIndex = 0
      // result.PointIndex = null
      //result.Distance = 4
      //result.RightSide = false
      // find the nearest vertex in the polgyon geometry to the pt
      result = GeometryEngine.Instance.NearestVertex(polygon, pt);
      // result.Point = 10, 1
      // result.PointIndex = 0
      // result.SegmentIndex = null
      // result.Distance = Math.Sqrt(41)
      // result.RightSide = false
    Reflect a polygon about a line
      Coordinate2D start = new(0, 0);
      Coordinate2D end = new(4, 4);
      LineSegment line = LineBuilderEx.CreateLineSegment(start, end, sr);
        new Coordinate2D(-1, 2),
      new Coordinate2D(-1, 4),
      // reflect a polygon about the line
      Polygon reflectedPolygon = GeometryEngine.Instance.ReflectAboutLine(polygon, line) as Polygon;
      // reflectedPolygon points are
      //    (2, -1), (4, -1), (4, 1), (2, -1)
    Determine relationship between two geometries
      // set up some geometries
      // points
      MapPoint point0 = MapPointBuilderEx.CreateMapPoint(0, 0, SpatialReferences.WGS84);
      MapPoint point1 = MapPointBuilderEx.CreateMapPoint(1, 1, SpatialReferences.WGS84);
      MapPoint point2 = MapPointBuilderEx.CreateMapPoint(-5, 5, SpatialReferences.WGS84);
      // multipoint
      List<MapPoint> points = [point0, point1, point2];
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(points, SpatialReferences.WGS84);
      // polygon
      List<Coordinate2D> polygonCoords =
          new Coordinate2D(-10, 0),
      new Coordinate2D(0, 10),
      new Coordinate2D(10, 0),
      polygon = PolygonBuilderEx.CreatePolygon(polygonCoords, SpatialReferences.WGS84);
      // polylines
      Polyline polyline1 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(-9.1, 0.1), new Coordinate2D(0, 9)), SpatialReferences.WGS84);
      Polyline polyline2 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(-5, 5), new Coordinate2D(0, 5)), SpatialReferences.WGS84);
      Polyline polyline3 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(2.09, -2.04), new Coordinate2D(5, 10)), SpatialReferences.WGS84);
      Polyline polyline4 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(10, -5), new Coordinate2D(10, 5)), SpatialReferences.WGS84);
      List<Segment> segments =
          LineBuilderEx.CreateLineSegment(new Coordinate2D(5.05, -2.87), new Coordinate2D(6.35, 1.57)),
      LineBuilderEx.CreateLineSegment(new Coordinate2D(6.35, 1.57), new Coordinate2D(4.13, 2.59)),
      LineBuilderEx.CreateLineSegment(new Coordinate2D(4.13, 2.59), new Coordinate2D(5, 5))
      Polyline polyline5 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(5, 5), new Coordinate2D(10, 10)));
      Polyline polyline6 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      Polyline polyline7 = PolylineBuilderEx.CreatePolyline(polyline5);
      Polyline polyline8 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(5, 5), new Coordinate2D(10, 10)), SpatialReferences.WGS84);
      segments.Clear();
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(0.6, 3.5), new Coordinate2D(0.7, 7)));
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(0.7, 7), new Coordinate2D(3, 9)));
      Polyline polyline9 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      // now do the Related tests
      // Interior/Interior Intersects
      string scl = "T********";
      bool related = GeometryEngine.Instance.Relate(polygon, polyline1, scl);     // related = true
      related = GeometryEngine.Instance.Relate(point0, point1, scl);              // related = false
      related = GeometryEngine.Instance.Relate(point0, multipoint, scl);          // related = true
      related = GeometryEngine.Instance.Relate(multipoint, polygon, scl);         // related = true
      related = GeometryEngine.Instance.Relate(multipoint, polyline1, scl);       // related = false
      related = GeometryEngine.Instance.Relate(polyline2, point2, scl);           // related = false
      related = GeometryEngine.Instance.Relate(point1, polygon, scl);             // related = true
      // Interior/Boundary Intersects
      scl = "*T*******";
      related = GeometryEngine.Instance.Relate(polygon, polyline2, scl);          // related = true
      related = GeometryEngine.Instance.Relate(polygon, polyline3, scl);          // related = false
      related = GeometryEngine.Instance.Relate(point1, polygon, scl);             // related = false
      // Boundary/Boundary Interior intersects
      scl = "***T*****";
      related = GeometryEngine.Instance.Relate(polygon, polyline4, scl);          // related = true
      // Overlaps Dim1
      scl = "1*T***T**";
      related = GeometryEngine.Instance.Relate(polygon, polyline5, scl);          // related = true
      // Crosses Area/Line (LineB crosses PolygonA)
      scl = "1020F1102";
      related = GeometryEngine.Instance.Relate(polygon, polyline6, scl);          // related = false
      related = GeometryEngine.Instance.Relate(polygon, polyline9, scl);          // related = true
      // Boundary/Boundary Touches
      scl = "F***T****";
      related = GeometryEngine.Instance.Relate(polygon, polyline7, scl);          // related = false
      related = GeometryEngine.Instance.Relate(polygon, polyline8, scl);          // related = true
    Reshape a polygon
      List<Coordinate2D> polygon1Coords =
        new Coordinate2D(0, -11000),
      new Coordinate2D(1000, -11000),
      new Coordinate2D(1000, -12000),
      new Coordinate2D(0, -12000),
      // reshaper coordinates intersect the polygon
      List<Coordinate2D> reshaperCoords =
        new Coordinate2D(1500, -11800),
      new Coordinate2D(-2600, -11800)
      SpatialReference sr = SpatialReferenceBuilder.CreateSpatialReference(102010);
      Polygon polygon1 = PolygonBuilderEx.CreatePolygon(polygon1Coords, sr);
      Polyline reshaper = PolylineBuilderEx.CreatePolyline(reshaperCoords, sr);
      Polygon outPolygon = GeometryEngine.Instance.Reshape(polygon1, reshaper) as Polygon;
      // outPolygon.PartCount = 1
      ReadOnlySegmentCollection segments = outPolygon.Parts[0];
      // segments.Count = 4
      // outPolygon.PointCount = 5
      string json = GeometryEngine.Instance.ExportToJson(JsonExportFlags.JsonExportSkipCRS, outPolygon);
      // json = "{\"rings\":[[[0,-11800],[0,-11000],[1000,-11000],[1000,-11800],[0,-11800]]]}";
      // example where the Reshaper polyline doesn't intersect the input
      reshaperCoords.Clear();
      reshaperCoords.Add(new Coordinate2D(1000, 1000));
      reshaperCoords.Add(new Coordinate2D(2000, 1000));
      // outPolygon = null
    Reverse the order of points in a Polygon
      Geometry g = GeometryEngine.Instance.ReverseOrientation(polygon);
      Polygon gPolygon = g as Polygon;
      // gPolygon.Points[0] = 1.0, 1.0
      // gPolygon.Points[1] = 2.0, 1.0
      // gPolygon.Points[2] = 2.0, 2.0
      // gPolygon.Points[3] = 1.0, 2.0
      // gPolygon.Points[4] = 1.0, 1.0
      // gPolygon.Area = -1 * polygon.Area
    Get Non Simple Reason
        Coordinate2D[] coords = [new Coordinate2D(5, 10), new Coordinate2D(15, 20), new Coordinate2D(25, 10), new Coordinate2D(5, 20)];
        polyline = PolylineBuilderEx.CreatePolyline(coords, sr);
        bool isSimple = GeometryEngine.Instance.GetNonSimpleReason(polyline, out NonSimpleReason nonSimpleReason);
        // isSimple = true;
        // nonSimpleReason = NonSimpleReason.IsSimple
        double resolution = sr.XYResolution;
        coords = [new Coordinate2D(0, 0), new Coordinate2D(0, 1.8 * resolution), new Coordinate2D(10, 10), new Coordinate2D(0, 5)];
        isSimple = GeometryEngine.Instance.GetNonSimpleReason(polyline, out nonSimpleReason);
        // isSimple = false
        // nonSimpleReason = NonSimpleReason.ShortSegments
        coords = [ new Coordinate2D(10, 10), new Coordinate2D(10, 20), new Coordinate2D(40, 20),
    new Coordinate2D(40, 10), new Coordinate2D(60, 10), new Coordinate2D(70, 10)];
        isSimple = GeometryEngine.Instance.GetNonSimpleReason(polygon, out nonSimpleReason);
        //isSimple = false
        //nonSimpleReason = NonSimpleReason.SelfIntersections
    Slice a Polygon into equal parts
      var slices = GeometryEngine.Instance.SlicePolygonIntoEqualParts(polygon, 3, 0, SliceType.Blocks);
      // slices.Count = 3
      // simple polygon
      Polygon p = PolygonBuilderEx.CreatePolygon(list2D);
      slices = GeometryEngine.Instance.SlicePolygonIntoEqualParts(p, 2, 0, SliceType.Strips);
      // slice[0] coordinates - (1.0, 1.0), (1.0, 1.5), (2.0, 1.5), (2.0, 1.0), (1.0, 1.0)
      // slice[1] coordinates - (1.0, 1.5), (1.0, 2.0), (2.0, 2.0), (2.0, 1.5), (1.0, 1.5)
      slices = GeometryEngine.Instance.SlicePolygonIntoEqualParts(p, 2, Math.PI / 4, SliceType.Strips);
      // slice[0] coordinates - (1.0, 1.0), (1.0, 2.0), (2.0, 1.0), (1.0, 1.0)
      // slice[1] coordinates - (1.0, 2.0), (2.0, 2.0), (2.0, 1.0), (1.0, 2.0)
    Get the individual parts of a multipart feature
    IEnumerable<Geometry> MultipartToSinglePart(Geometry inputGeometry)
      // list holding the part(s) of the input geometry
      List<Geometry> singleParts = new List<Geometry>();
      // check if the input is a null pointer or if the geometry is empty
      if (inputGeometry == null || inputGeometry.IsEmpty)
        return singleParts;
      // based on the type of geometry, take the parts/points and add them individually into a list
      switch (inputGeometry.GeometryType)
        case GeometryType.Envelope:
          singleParts.Add(inputGeometry.Clone() as Envelope);
          break;
        case GeometryType.Multipatch:
          singleParts.Add(inputGeometry.Clone() as Multipatch);
          break;
        case GeometryType.Multipoint:
          var multiPoint = inputGeometry as Multipoint;
          foreach (var point in multiPoint.Points)
            // add each point of collection as a standalone point into the list
            singleParts.Add(point);
          break;
        case GeometryType.Point:
          singleParts.Add(inputGeometry.Clone() as MapPoint);
          break;
        case GeometryType.Polygon:
          var polygonNew = inputGeometry as Polygon;
          foreach (var polygonPart in polygonNew.Parts)
            // use the PolygonBuilderEx turning the segments into a standalone
            // polygon instance
            singleParts.Add(PolygonBuilderEx.CreatePolygon(polygonPart));
          break;
        case GeometryType.Polyline:
          var polylineNew = inputGeometry as Polyline;
          foreach (var polylinePart in polyline.Parts)
            // use the PolylineBuilderEx turning the segments into a standalone
            // polyline instance
            singleParts.Add(PolylineBuilderEx.CreatePolyline(polylinePart));
          break;
        case GeometryType.Unknown:
          break;
        default:
          break;
      return singleParts;
    Requirements
