ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / ToGeometry() Method
Example
    ToGeometry() Method
    Returns a Polyline instance representing the current state of the builder.
    Syntax
    public new Polyline ToGeometry()
    Public Shadows Function ToGeometry() As Polyline
    Return Value
    Example
    Construct a Polyline - from an enumeration of MapPoints
      // Use a builderEx convenience method or a builderEx constructor.
      // neither need to run on the MCT
      MapPoint startPt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
      MapPoint endPt = MapPointBuilderEx.CreateMapPoint(2.0, 1.0);
      List<MapPoint> list = new List<MapPoint>() { startPt, endPt };
      Polyline polylineFromPointList = PolylineBuilderEx.CreatePolyline(list, SpatialReferences.WGS84);
      // use AttributeFlags.None since we only have 2D points in the list
      PolylineBuilderEx pb = new PolylineBuilderEx(list, AttributeFlags.None);
      pb.SpatialReference = SpatialReferences.WGS84;
      Polyline polyline2 = pb.ToGeometry();
      // Use AttributeFlags.NoAttributes because we only have 2d points in the list
      Polyline polyline4 = PolylineBuilderEx.CreatePolyline(list, AttributeFlags.None);
    Reverse the order of points in a Polyline
      var polylineBuilder = new PolylineBuilderEx(polyline);
      polylineBuilder.ReverseOrientation();
      Polyline reversedPolyline = polylineBuilder.ToGeometry();
    Build a multi-part Polyline
      List<MapPoint> firstPoints = new List<MapPoint>();
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(1.0, 1.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(1.0, 2.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(2.0, 2.0));
      firstPoints.Add(MapPointBuilderEx.CreateMapPoint(2.0, 1.0));
      List<MapPoint> nextPoints = new List<MapPoint>();
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(11.0, 1.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(11.0, 2.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(12.0, 2.0));
      nextPoints.Add(MapPointBuilderEx.CreateMapPoint(12.0, 1.0));
      // use AttributeFlags.None since we have 2D points in the list
      PolylineBuilderEx pBuilder = new PolylineBuilderEx(firstPoints, AttributeFlags.None);
      pBuilder.AddPart(nextPoints);
      Polyline polylineFromBuilder = pBuilder.ToGeometry();
      // polyline has 2 parts
      pBuilder.RemovePart(0);
      // polyline has 1 part
    Split Polyline at distance
      // create list of points
      // BuilderEx constructors don't need to run on the MCT.
      // use the PolylineBuilder as we wish to manipulate the geometry
      // use AttributeFlags.None as we have 2D points
      PolylineBuilderEx polylineBuilder = new PolylineBuilderEx(list, AttributeFlags.None);
      // split at a distance 0.75
      polylineBuilder.SplitAtDistance(0.75, false);
      // get the polyline
      Polyline polylineFromBuilder = polylineBuilder.ToGeometry();
      // polyline should have 3 points  (1,1), (1.75, 1), (2,1)
      // add another path
      MapPoint p1 = MapPointBuilderEx.CreateMapPoint(4.0, 1.0);
      MapPoint p2 = MapPointBuilderEx.CreateMapPoint(6.0, 1.0);
      MapPoint p3 = MapPointBuilderEx.CreateMapPoint(7.0, 1.0);
      List<MapPoint> pts = new List<MapPoint>() { p1, p2, p3 };
      polylineBuilder.AddPart(pts);
      // polyline has 2 parts. Each part has 3 points
      // split the 2nd path half way - don't create a new path
      polylineBuilder.SplitPartAtDistance(1, 0.5, true, false);
      // polyline still has 2 parts; but now has 7 points
    Create 3D Polyline and set Z-values while preserving curve segments
      PolylineBuilderEx polylineBuilder = new PolylineBuilderEx(polyline);
      polylineBuilder.HasZ = true;
      // The HasZ property is set to true for all the points in
      // polyline3D when you call ToGeometry().
      Polyline polyline3D = polylineBuilder.ToGeometry();
      // For this example, create Z-values.
      // You may want to pass them in as a parameter.
      int numPoints = polyline3D.PointCount;
      double[] zValues = new double[numPoints];
      for (int i = 0; i < numPoints; i++)
        zValues[i] = i % 2 == 0 ? 2 : 1;
      // We need to know at which point index each part starts
      int partPointIndex = 0;
      int numParts = polyline3D.PartCount;
      for (int i = 0; i < numParts; i++)
        var part = polyline3D.Parts[i];
        int numSegmentsInPolyline3D = part.Count;
        for (int j = 0; j < numSegmentsInPolyline3D; j++)
          Segment segment = part[j];
          MapPointBuilderEx pointBuilder = new MapPointBuilderEx(segment.StartPoint);
          pointBuilder.Z = zValues[partPointIndex++];
          MapPoint startPoint = pointBuilder.ToGeometry();
          // Make sure that the end point of this segment is the same as the start point of the next segment
          pointBuilder = new MapPointBuilderEx(segment.EndPoint);
          pointBuilder.Z = zValues[partPointIndex];
          MapPoint endPoint = pointBuilder.ToGeometry();
          SegmentType segmentType = segment.SegmentType;
          SegmentBuilderEx segmentBuilder = null;
          switch (segmentType)
            case SegmentType.Line:
              segmentBuilder = new LineBuilderEx((LineSegment)segment);
              break;
            case SegmentType.Bezier:
              segmentBuilder = new CubicBezierBuilderEx((CubicBezierSegment)segment);
              break;
            case SegmentType.EllipticArc:
              segmentBuilder = new EllipticArcBuilderEx((EllipticArcSegment)segment);
              break;
          // Only change the start and end point which now have Z-values set.
          // This will preserve the curve if the segment is an EllipticArcSegment or CubicBezierSegment.
          segmentBuilder.StartPoint = startPoint;
          segmentBuilder.EndPoint = endPoint;
          segment = segmentBuilder.ToSegment();
          polylineBuilder.ReplaceSegment(i, j, segment);
        // Move point index for the next part
        partPointIndex++;
    Determine if all the M-values are numbers - IsMSimple
      Coordinate2D[] coords = [new Coordinate2D(-2, 2), new Coordinate2D(3, 5), new Coordinate2D(7, 2)];
      polyline = PolylineBuilderEx.CreatePolyline(coords); // polyline.HasM = false
      bool isMSimple = GeometryEngine.Instance.IsMSimple(polyline); // isMSimple = false
      PolylineBuilderEx polylineBuilder = new(polyline)
        HasM = true
      polyline = polylineBuilder.ToGeometry();
      MapPoint point1 = MapPointBuilderEx.CreateMapPoint(-2, 2, -1, 1);
      MapPoint point2 = MapPointBuilderEx.CreateMapPoint(3, 5, -2, 2);
      MapPoint[] points = [point1, point2];
      polyline = PolylineBuilderEx.CreatePolyline(points, AttributeFlags.HasM);
      isMSimple = GeometryEngine.Instance.IsMSimple(polyline); // isMSimple = true
    Requirements
