ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / ConstructGeodeticLineFromDistance Method
The type of geodetic curve to be created.
The from point.
The length of the geodetic line to be created.
The azimuth (in degrees) of the geodetic line to be created. Measured clockwise from the north.
The linear unit of the length. Also the linear unit of the densifyParameter if the densifyMode is DensifyByLength. If this is null, the units are assumed to be meters.
The densification mode.
The densification parameter.
Example
    ConstructGeodeticLineFromDistance Method (IGeometryEngine)
    Constructs a geodetic line with the specified length and azimuth.
    Syntax
    Parameters
    curveType
    fromPoint
    The from point.
    length
    azimuth
    linearUnit
    densifyMode
    densifyParameter
    Return Value
    Returns the created geodetic line.
    Exceptions
    Remarks
    If the densifyMode is DensifyByLength, then the densifyParameter specifies the maximum segment length.
    If the densifyMode is DensifyByDeviation, then it is the maximum distance from the true geodetic line to the densified output.
    Example
    Construct a geodetic line with specified distance and azimuth
      var sr = SpatialReferenceBuilder.CreateSpatialReference(4326);
      var mapPoint = MapPointBuilderEx.CreateMapPoint(15, 60, sr);
      // calculate
      var polylineGeodetic = GeometryEngine.Instance.ConstructGeodeticLineFromDistance(GeodeticCurveType.Loxodrome, mapPoint, 5000000, 45, null, CurveDensifyMethod.ByLength, 300000);
    Requirements
