ArcGIS.Core.Geometry Namespace / MultipatchBuilderEx Class / CreateMultipatch Method / CreateMultipatch(MultipatchConstructType,MapPoint,Double,Double,SpatialReference) Method
The type of multipatch to be constructed.
The center point of the Multipatch.
The size of the shape (height, length, width). It must be greater than 0.
A value between 0 and 1 inclusive. A higher quality number means more verticies for the shape resulting in a smoother shape.
(Optional)The spatial reference of the Multipatch.
Example
    Convenience method to quickly create a new Multipatch object. Use this constructor to create a cylinder, sphere, sphere frame or cone centered around the centerPt of the specified size and quality.
    Syntax
    Public Overloads Shared Function CreateMultipatch( _
       ByVal constructType As MultipatchConstructType, _
       ByVal centerPt As MapPoint, _
       ByVal size As Double, _
       ByVal quality As Double, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Multipatch
    Parameters
    constructType
    centerPt
    size
    quality
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    The centerPt is empty or null.
    The size is invalid. It must be greater than 0.
    The quality is invalid. It must be between 0 and 1 inclusive.
    The constructType is invalid for this constructor.
    Example
    Construct 3D special Multipatch shapes
      var sr = MapView.Active.Map.SpatialReference;
      var extent = MapView.Active.Extent;
      var center = extent.Center;
      var centerZ = MapPointBuilderEx.CreateMapPoint(center.X, center.Y, 500, sr);
      // cube
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cube, centerZ, 200, sr);
      // tetrahedron
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Tetrahedron, centerZ, 200, sr);
      // diamond
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Diamond, centerZ, 200, sr);
      // hexagon
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Hexagon, centerZ, 200, sr);
      // sphere frame
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.SphereFrame, centerZ, 200, 0.8, sr);
      // sphere
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Sphere, centerZ, 200, 0.8, sr);
      // cylinder
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cylinder, centerZ, 200, 0.8, sr);
      // cone
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cone, centerZ, 200, 0.8, sr);
      // use the builder to add materials or textures
      // create the multipatchBuilderEx object
      var builder = new ArcGIS.Core.Geometry.MultipatchBuilderEx(multipatch);
      //   - create a cone with a material
      builder = new MultipatchBuilderEx(MultipatchConstructType.Cone, centerZ, 200, 0.8, sr);
      BasicMaterial faceMaterial = new BasicMaterial();
      faceMaterial.Color = System.Windows.Media.Color.FromRgb(255, 0, 0);
      faceMaterial.Shininess = 150;
      faceMaterial.TransparencyPercent = 50;
      faceMaterial.EdgeWidth = 20;
      foreach (var patch in builder.Patches)
        patch.Material = faceMaterial;
      multipatch = builder.ToGeometry() as Multipatch;
    Requirements
