ArcGIS.Desktop.Core Namespace / ApplicationOptions Class / DownloadOptions Property
Example
    Gets the application download options.
    Syntax
    public static DownloadOptions DownloadOptions {get;}
    Public Shared ReadOnly Property DownloadOptions As DownloadOptions
    Example
    Get DownloadOptions
      var staging = ApplicationOptions.DownloadOptions.StagingLocation;
      var ppkx_loc = ApplicationOptions.DownloadOptions.UnpackPPKXLocation;
      var ask_ppkx_loc = ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation;
      var other_loc = ApplicationOptions.DownloadOptions.UnpackOtherLocation;
      var ask_other_loc = ApplicationOptions.DownloadOptions.AskForUnpackOtherLocation;
      var use_proj_folder = ApplicationOptions.DownloadOptions.UnpackOtherToProjectLocation;
      var offline_loc = ApplicationOptions.DownloadOptions.OfflineMapsLocation;
      var ask_offline_loc = ApplicationOptions.DownloadOptions.AskForOfflineMapsLocation;
      var use_proj_folder_offline = ApplicationOptions.DownloadOptions.OfflineMapsToProjectLocation;
    Set Staging Location for Sharing and Publishing
      ApplicationOptions.DownloadOptions.StagingLocation = @"D:\data\staging";
    Set DownloadOptions for PPKX
      //Options are mutually exclusive.
      //Setting ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation = true
      //supersedes any value in ApplicationOptions.DownloadOptions.UnpackPPKXLocation
      //and will prompt the user on an unpack. The value of
      //ApplicationOptions.DownloadOptions.UnpackPPKXLocation will be unaffected
      //and is ignored. This is the same behavior as on the Pro UI.
      ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation = true;//override location
      //The default location is typically <My Documents>\ArcGIS\Packages
      //Setting ApplicationOptions.DownloadOptions.UnpackPPKXLocation to any
      //location overrides ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation
      //and sets it to false. This is the same behavior as on the Pro UI.
      ApplicationOptions.DownloadOptions.UnpackPPKXLocation = @"D:\data\for_ppkx";
      //Or, if ApplicationOptions.DownloadOptions.UnpackPPKXLocation already
      //contains a valid path, set ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation
      //explicitly to false to use the UnpackPPKXLocation
      if (!string.IsNullOrEmpty(ApplicationOptions.DownloadOptions.UnpackPPKXLocation))
        ApplicationOptions.DownloadOptions.AskForUnpackPPKXLocation = false;
    Set DownloadOptions for UnpackOther
      //UnpackOther settings control unpacking of anything _other than_
      //a ppkx or aptx. Options are mutually exclusive.
      //Set ApplicationOptions.DownloadOptions.UnpackOtherLocation explicitly to
      //toggle ApplicationOptions.DownloadOptions.AskForUnpackOtherLocation and
      //ApplicationOptions.DownloadOptions.UnpackOtherToProjectLocation to false
      //Note: default is typically <My Documents>\ArcGIS\Packages, _not_ null.
      //This is the same behavior as on the Pro UI.
      ApplicationOptions.DownloadOptions.UnpackOtherLocation = @"D:\data\for_other";
      //or...to use a location already stored in UnpackOtherLocation as the
      //default without changing it,
      //set ApplicationOptions.DownloadOptions.AskForUnpackOtherLocation and
      //explicitly. This is the same behavior as on the Pro UI.
      if (!string.IsNullOrEmpty(ApplicationOptions.DownloadOptions.UnpackOtherLocation))
        ApplicationOptions.DownloadOptions.AskForUnpackOtherLocation = false;
        ApplicationOptions.DownloadOptions.UnpackOtherToProjectLocation = false;
      //Setting ApplicationOptions.DownloadOptions.AskForUnpackOtherLocation to
      //true overrides any UnpackOtherLocation value and sets
      //ApplicationOptions.DownloadOptions.UnpackOtherToProjectLocation to false.
      ApplicationOptions.DownloadOptions.AskForUnpackOtherLocation = true;
      //Setting ApplicationOptions.DownloadOptions.UnpackOtherToProjectLocation to
      //ApplicationOptions.DownloadOptions.AskForUnpackOtherLocation to false.
    Set DownloadOptions for OfflineMaps
      //OfflineMaps settings control where map content that is taken
      //offline is copied to on the local machine. Options are mutually exclusive.
      //Set ApplicationOptions.DownloadOptions.OfflineMapsLocation explicitly to
      //toggle ApplicationOptions.DownloadOptions.AskForOfflineMapsLocation and
      //ApplicationOptions.DownloadOptions.OfflineMapsToProjectLocation to false
      //Note: default is typically <My Documents>\ArcGIS\OfflineMaps, _not_ null.
      ApplicationOptions.DownloadOptions.OfflineMapsLocation = @"D:\data\for_offline";
      //or...to use a location already stored in OfflineMapsLocation as the
      //set ApplicationOptions.DownloadOptions.AskForOfflineMapsLocation and
      //explicitly.
      if (!string.IsNullOrEmpty(ApplicationOptions.DownloadOptions.OfflineMapsLocation))
        ApplicationOptions.DownloadOptions.AskForOfflineMapsLocation = false;
        ApplicationOptions.DownloadOptions.OfflineMapsToProjectLocation = false;
      //Setting ApplicationOptions.DownloadOptions.AskForOfflineMapsLocation to
      //true overrides any OfflineMapsLocation value and sets
      //ApplicationOptions.DownloadOptions.OfflineMapsToProjectLocation to false.
      ApplicationOptions.DownloadOptions.AskForOfflineMapsLocation = true;
      //Setting ApplicationOptions.DownloadOptions.OfflineMapsToProjectLocation to
      //ApplicationOptions.DownloadOptions.AskForOfflineMapsLocation to false.
      ApplicationOptions.DownloadOptions.OfflineMapsToProjectLocation = true;
    Requirements
