public static EditingOptions EditingOptions {get;}
Public Shared ReadOnly Property EditingOptions As EditingOptions
//toggle, switch Editing option values
var options = ApplicationOptions.EditingOptions;
options.EnforceAttributeValidation = !options.EnforceAttributeValidation;
options.WarnOnSubtypeChange = !options.WarnOnSubtypeChange;
options.InitializeDefaultValuesOnSubtypeChange = !options.InitializeDefaultValuesOnSubtypeChange;
options.UncommitedAttributeEdits = (options.UncommitedAttributeEdits ==
UncommitedEditMode.AlwaysPrompt) ? UncommitedEditMode.Apply : UncommitedEditMode.AlwaysPrompt;
options.StretchGeometry = !options.StretchGeometry;
options.StretchTopology = !options.StretchTopology;
options.UncommitedGeometryEdits = (options.UncommitedGeometryEdits ==
options.ActivateMoveAfterPaste = !options.ActivateMoveAfterPaste;
options.ShowFeatureSketchSymbology = !options.ShowFeatureSketchSymbology;
options.FinishSketchOnDoubleClick = !options.FinishSketchOnDoubleClick;
options.AllowVertexEditingWhileSketching = !options.AllowVertexEditingWhileSketching;
options.ShowDeleteDialog = !options.ShowDeleteDialog;
options.EnableStereoEscape = !options.EnableStereoEscape;
options.DragSketch = !options.DragSketch;
options.ShowDynamicConstraints = !options.ShowDynamicConstraints;
options.IsDeflectionDefaultDirectionConstraint =
!options.IsDeflectionDefaultDirectionConstraint;
options.IsDirectionDefaultInputConstraint = !options.IsDirectionDefaultInputConstraint;
options.ShowEditingToolbar = !options.ShowEditingToolbar;
options.ToolbarPosition = (options.ToolbarPosition == ToolbarPosition.Bottom) ?
ToolbarPosition.Right : ToolbarPosition.Bottom;
options.ToolbarSize = (options.ToolbarSize == ToolbarSize.Medium) ?
ToolbarSize.Small : ToolbarSize.Medium;
options.MagnifyToolbar = !options.MagnifyToolbar;
options.EnableEditingFromEditTab = !options.EnableEditingFromEditTab;
options.AutomaticallySaveEdits = !options.AutomaticallySaveEdits;
options.AutoSaveByTime = !options.AutoSaveByTime;
options.SaveEditsInterval = (options.AutomaticallySaveEdits) ? 20 : 10;
options.SaveEditsOperations = (options.AutomaticallySaveEdits) ? 60 : 30;
options.SaveEditsOnProjectSave = !options.SaveEditsOnProjectSave;
options.ShowSaveEditsDialog = !options.ShowSaveEditsDialog;
options.ShowDiscardEditsDialog = !options.ShowDiscardEditsDialog;
options.DeactivateToolOnSaveOrDiscard = !options.DeactivateToolOnSaveOrDiscard;
options.NewLayersEditable = !options.NewLayersEditable;
var eOptions = ApplicationOptions.EditingOptions;
var followLinkedLines = eOptions.AutomaticallyFollowLinkedLineFeatures;
var followLinedPolygons = eOptions.AutomaticallyFollowLinkedPolygonFeatures;
var usePlacementProps = eOptions.UseAnnotationPlacementProperties;
var followMode = eOptions.AnnotationFollowMode;
var placementMode = eOptions.AnnotationPlacementMode;
eOptions.AnnotationFollowMode = AnnotationFollowMode.Parallel;
eOptions.AnnotationPlacementMode = AnnotationPlacementMode.Left;
await QueuedTask.Run(() =>
//There are 4 vertex symbol settings - selected, unselected and the
//current vertex selected and unselected.
var reg_select = options.GetVertexSymbolOptions(VertexSymbolType.RegularSelected);
var reg_unsel = options.GetVertexSymbolOptions(VertexSymbolType.RegularUnselected);
var curr_sel = options.GetVertexSymbolOptions(VertexSymbolType.CurrentSelected);
var curr_unsel = options.GetVertexSymbolOptions(VertexSymbolType.CurrentUnselected);
//to convert the options to a symbol use
//GetPointSymbol
var reg_sel_pt_symbol = reg_select.GetPointSymbol();
//ditto for reg_unsel, curr_sel, curr_unsel
//var options = ApplicationOptions.EditingOptions;
var seg_options = options.GetSegmentSymbolOptions();
//SymbolFactory. Note: this is approximate....sketch isn't using the
//CIM directly for segments
var layers = new List<CIMSymbolLayer>();
var stroke0 = SymbolFactory.Instance.ConstructStroke(seg_options.PrimaryColor,
seg_options.Width, SimpleLineStyle.Dash);
layers.Add(stroke0);
if (seg_options.HasSecondaryColor)
var stroke1 = SymbolFactory.Instance.ConstructStroke(
seg_options.SecondaryColor, seg_options.Width, SimpleLineStyle.Solid);
layers.Add(stroke1);
//segment symbology only
var sketch_line = new CIMLineSymbol()
SymbolLayers = layers.ToArray()
