ArcGIS.Desktop.Core Namespace / ApplicationOptions Class / TextAndGraphicsElementsOptions Property
Example
    Gets the application text and graphics elements options.
    Syntax
    public static TextAndGraphicsElementsOptions TextAndGraphicsElementsOptions {get;}
    Public Shared ReadOnly Property TextAndGraphicsElementsOptions As TextAndGraphicsElementsOptions
    Remarks
    Use to set the default font and default point, line, polygon, and text symbology for graphics elements
    Example
    Get All Available Fonts
      //Note: see also SymbolFactory.Instance.GetAvailableFonts() which returns the
      //same list. Use for TextAndGraphicsElementsOptions.GetAvailableFonts() convenience
      //A list of tuples of Font name + associated Font Styles, one tuple per
      //font, is returned
      await QueuedTask.Run(() =>
        var fonts = ApplicationOptions.TextAndGraphicsElementsOptions.GetAvailableFonts();
        StringBuilder sb = new StringBuilder();
        sb.AppendLine("Pro Fonts\r\n============================");
        foreach (var font in fonts)
          var styles = string.Join(",", font.fontStyles);
          sb.AppendLine($"{font.fontName}, [{styles}]");
        System.Diagnostics.Debug.WriteLine(sb.ToString());
    Get TextAndGraphicsElementsOptions
        //Get the default font (see also 'SymbolFactory.Instance.DefaultFont')
        var def_font = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultFont();
          $"\r\ndefault font: {def_font.fontName}, {def_font.styleName}");
        //Get the default graphics element symbols - point, line, poly, text
        var ptSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPointSymbol();
        var lineSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultLineSymbol();
        var polySymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPolygonSymbol();
        var textSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultTextSymbol();
    Set TextAndGraphicsElementsOptions
        //Set a default font. Use its default style
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
        //or specify an explicit style
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
        //Create symbols
        var ptSymbol2 = SymbolFactory.Instance.ConstructPointSymbol(
          ColorFactory.Instance.RedRGB, 14, SimpleMarkerStyle.Diamond);
        var lineSymbol2 = SymbolFactory.Instance.ConstructLineSymbol(
          ColorFactory.Instance.RedRGB, 2, SimpleLineStyle.Dash);
        var polySymbol2 = SymbolFactory.Instance.ConstructPolygonSymbol(
          ColorFactory.Instance.RedRGB, SimpleFillStyle.DiagonalCross);
        var textSymbol2 = SymbolFactory.Instance.ConstructTextSymbol(
          ColorFactory.Instance.RedRGB, 12);
        //Set default point, line, poly, text graphics element symbols
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPointSymbol(ptSymbol2);
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultLineSymbol(lineSymbol2);
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPolygonSymbol(polySymbol2);
        ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultTextSymbol(textSymbol2);
    Requirements
