ArcGIS.Desktop.Core Namespace / EditingOptions Class / GetDefaultVertexSymbolOptions Method
The type of vertex symbol to obtain.
Example
    Gets the default symbol information for a vertex while sketching. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public VertexSymbolOptions GetDefaultVertexSymbolOptions(
       VertexSymbolType symbolType
    Public Function GetDefaultVertexSymbolOptions( _
       ByVal symbolType As VertexSymbolType _
    ) As VertexSymbolOptions
    Parameters
    symbolType
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Set Sketch Vertex Symbol Back to Default
      var options = ApplicationOptions.EditingOptions;
      //var options = ApplicationOptions.EditingOptions;
      await QueuedTask.Run(() =>
        //ditto for reg selected and current selected, unselected
        var def_reg_unsel =
          options.GetDefaultVertexSymbolOptions(VertexSymbolType.RegularUnselected);
        //apply default
        options.SetVertexSymbolOptions(
          VertexSymbolType.RegularUnselected, def_reg_unsel);
    Requirements
