| Name | Description | |
![]() | ActivateMoveAfterPaste | Gets and sets if Move tool is to be activated after all paste operations. |
![]() | AllowMergeToCreateNonPlanarPolygons | Gets and sets whether the merge tool merges z-aware polygons when they overlap. |
![]() | AllowVertexEditingWhileSketching | Gets and sets whether vertex editing is allowed while sketching. |
![]() | AnnotationFollowMode | Gets and sets the feature linked annotation follow mode. This describes how new annotation aligns to the line or boundary feature it is following. |
![]() | AnnotationPlacementMode | Gets and sets the feature linked annotation placement mode for new annotation relative to the direction of the line or boundary feature it is following. |
![]() | AutoApplyAttributeEdits | Gets and sets whether attribute edits are automatically applied. |
![]() | AutomaticallyFollowLinkedLineFeatures | Gets and sets whether feature linked annotation automatically follows linked line features. |
![]() | AutomaticallyFollowLinkedPolygonFeatures | Gets and sets whether feature linked annotation automatically follows linked polygon features. |
![]() | AutomaticallySaveEdits | Gets and sets whether edits are to be automatically saved. |
![]() | AutoSaveByTime | Gets and sets whether edits are to be saved by time or operation when AutomaticallySaveEdits is true. |
![]() | DeactivateToolOnSaveOrDiscard | Gets and sets whether the active editing tool is deactivated when saving or discarding edits. |
![]() | DefaultFallbackTool | Gets the default fallback tool. This is the "esri_mapping_exploreTool". |
![]() | DragSketch | Gets and sets the sketch behavior on a touch pad (click + drag vs click-drag-click) |
![]() | EnableAnnoResize | Gets and sets option to enable resize for selected annotation feature. |
![]() | EnableAnnoRotate | Gets and sets option to enable rotation for selected annotation feature. |
![]() | EnableControlPoints | Gets and sets whether to enable control points on the sketch |
![]() | EnableEditingFromEditTab | Gets and sets whether editing can be enabled and disabled from the Edit tab. |
![]() | EnableStereoEscape | Gets and sets whether the Escape key is enabled as a shortcut to cancel the active tool in Stereo maps. |
![]() | EnforceAttributeValidation | Gets and sets whether attribute validation is enforced. |
![]() | FallbackTool | Gets and sets the current fallback tool. This tool will be activated when an editing tool is deactivated. |
![]() | FinishSketchOnDoubleClick | Gets and sets whether double-click is enabled as a shortcut for Finish when sketching. |
![]() | HighlightLayerOnSelectionChange | Gets and sets whether the layer should be highlighted in the attributes window selection view when the selection changes. |
![]() | InitializeDefaultValuesOnSubtypeChange | Gets and sets whether default values are initialized on a subtype change. |
![]() | IsDeflectionDefaultDirectionConstraint | Gets and sets whether Deflection is the default direction constraint. Set to false for Absolute to be the default direction constraint. |
![]() | IsDirectionDefaultInputConstraint | Gets and sets whether Direction is the default constraint for input mode. Set to false for Distance to be the default constraint for input mode. |
![]() | IsSingleWorkspaceEditSession | Gets and sets whether only data from a single workspace can be edited within an edit session. Specify the workspace to be edited using the |
![]() | MagnifyToolbar | Gets and sets whether the editing toolbar is magnified. |
![]() | NewLayersEditable | Gets and sets whether newly added layers are editable by default. |
![]() | SaveEditsInterval | Gets and sets the time interval (in minutes) after which edits will be saved if AutomaticallySaveEdits is true and AutoSaveByTime is true. |
![]() | SaveEditsOnProjectSave | Gets and sets whether edits are saved when saving project. |
![]() | SaveEditsOperations | Gets and sets the number of operations after which edits will be saved if AutomaticallySaveEdits is true and AutoSaveByTime is false. |
![]() | ShowDeleteDialog | Gets and sets whether the dialog to confirm deletes is displayed. |
![]() | ShowDiscardEditsDialog | Gets and sets whether the dialog to confirm discard edits is displayed. |
![]() | ShowDynamicConstraints | Gets and sets whether dynamic constraints are displayed in the map |
![]() | ShowEditingToolbar | Gets and sets whether the editing toolbar is visible. |
![]() | ShowFeatureSketchSymbology | Gets and sets whether feature symbology is displayed in the sketch. |
![]() | ShowGeometricConstraints | Gets and sets whether geometric constraints are displayed when drawing. |
![]() | ShowSaveEditsDialog | Gets and sets whether the dialog to confirm save edits is displayed. |
![]() | StretchGeometry | Gets and sets whether geometry is stretched proportionately when moving a vertex. |
![]() | StretchTopology | Gets and sets whether topology is stretched proportionately when moving a topology element. |
![]() | ToolbarPosition | Gets and sets the editing toolbar position. |
![]() | ToolbarSize | Gets and sets the editing toolbar size. |
![]() | UncommitedAttributeEdits | Gets and sets the uncommitted attribute edits setting. |
![]() | UncommitedGeometryEdits | Gets and sets the uncommitted geometry edits setting. |
![]() | UseAnnotationPlacementProperties | Gets and sets whether feature linked annotation uses placement properties defined in the annotation class. |
![]() | WarnOnSubtypeChange | Gets and sets whether a warning is displayed when subtypes are changed. |
