ArcGIS.Desktop.Core Namespace / EditingOptions Class / CanSetVertexSymbolOptions Method
The type of vertex symbol to obtain.
The vertex symbol.
Example
    Determines if the vertex sketch symbol can be set.
    Syntax
    public bool CanSetVertexSymbolOptions(
       VertexSymbolType symbolType,
       VertexSymbolOptions vertexSymbol
    Public Function CanSetVertexSymbolOptions( _
       ByVal symbolType As VertexSymbolType, _
       ByVal vertexSymbol As VertexSymbolOptions _
    ) As Boolean
    Parameters
    symbolType
    vertexSymbol
    The vertex symbol.
    Return Value
    True if the vertex symbol options are valid. False otherwise.
    Remarks
    This function should be called prior to SetVertexSymbolOptions to ensure the parameters are valid. It checks the following
    • Outline width can be null or a positive number (ie greater than 0)
    • Size can be null or a positive number (ie greater than 0)
    • Angle rotation can be null or between -360 and 360
    Example
    Set Sketch Vertex Symbol Options
      var options = ApplicationOptions.EditingOptions;
      //var options = ApplicationOptions.EditingOptions;
      await QueuedTask.Run(() =>
        //change the regular unselected vertex symbol
        //default is a green, hollow, square, 5pts. Change to
        //Blue outline diamond, 10 pts
        var vertexSymbol = new VertexSymbolOptions(VertexSymbolType.RegularUnselected);
        vertexSymbol.OutlineColor = ColorFactory.Instance.BlueRGB;
        vertexSymbol.MarkerType = VertexMarkerType.Diamond;
        vertexSymbol.Size = 10;
        //Are these valid?
        if (options.CanSetVertexSymbolOptions(
             VertexSymbolType.RegularUnselected, vertexSymbol))
          //apply them
          options.SetVertexSymbolOptions(VertexSymbolType.RegularUnselected, vertexSymbol);
    Requirements
