ArcGIS.Desktop.Core Namespace / EditingOptions Class / SetVertexSymbolOptions Method
The type of vertex symbol to obtain.
The new vertex symbol.
Example
    Sets the symbol for a vertex while sketching. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetVertexSymbolOptions(
       VertexSymbolType symbolType,
       VertexSymbolOptions vertexSymbol
    Public Sub SetVertexSymbolOptions( _
       ByVal symbolType As VertexSymbolType, _
       ByVal vertexSymbol As VertexSymbolOptions _
    Parameters
    symbolType
    vertexSymbol
    Exceptions
    ExceptionDescription
    Symbol options are not valid. See CanSetVertexSymbolOptions for details on option settings.
    Remarks
    This method calls the CanSetVertexSymbolOptions function prior to setting the symbol values. If the options are invalid, no updates are made to the symbol.
    Example
    Set Sketch Vertex Symbol Options
      var options = ApplicationOptions.EditingOptions;
      //var options = ApplicationOptions.EditingOptions;
      await QueuedTask.Run(() =>
        //change the regular unselected vertex symbol
        //default is a green, hollow, square, 5pts. Change to
        //Blue outline diamond, 10 pts
        var vertexSymbol = new VertexSymbolOptions(VertexSymbolType.RegularUnselected);
        vertexSymbol.OutlineColor = ColorFactory.Instance.BlueRGB;
        vertexSymbol.MarkerType = VertexMarkerType.Diamond;
        vertexSymbol.Size = 10;
        //Are these valid?
        if (options.CanSetVertexSymbolOptions(
             VertexSymbolType.RegularUnselected, vertexSymbol))
          //apply them
          options.SetVertexSymbolOptions(VertexSymbolType.RegularUnselected, vertexSymbol);
    Set Sketch Vertex Symbol Back to Default
        //ditto for reg selected and current selected, unselected
        var def_reg_unsel =
          options.GetDefaultVertexSymbolOptions(VertexSymbolType.RegularUnselected);
        //apply default
          VertexSymbolType.RegularUnselected, def_reg_unsel);
    Requirements
