public void SetSegmentSymbolOptions( SegmentSymbolOptions segmentSymbol )
Public Sub SetSegmentSymbolOptions( _ ByVal segmentSymbol As SegmentSymbolOptions _ )
Parameters
- segmentSymbol
- The new segment symbol
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.ArgumentException | Symbol options are not valid. See CanSetSegmentSymbolOptions for details on option settings. |
var options = ApplicationOptions.EditingOptions;
//var options = ApplicationOptions.EditingOptions;
await QueuedTask.Run(() =>
//change the segment symbol primary color to green and
//width to 1 pt
var segSymbol = options.GetSegmentSymbolOptions();
segSymbol.PrimaryColor = ColorFactory.Instance.GreenRGB;
segSymbol.Width = 1;
//Are these valid?
if (options.CanSetSegmentSymbolOptions(segSymbol))
//apply them
options.SetSegmentSymbolOptions(segSymbol);
var def_seg = options.GetDefaultSegmentSymbolOptions();
options.SetSegmentSymbolOptions(def_seg);
