Public Shared Function GetParcelFabric( _ ByVal parcelLayer As ParcelLayer _ ) As ParcelFabric
public static ParcelFabric GetParcelFabric( ParcelLayer parcelLayer )
Parameters
- parcelLayer
- The parcel layer.
| Exception | Description |
| ArcGIS.Core.Licensing.Exceptions.LicenseException | Insufficient license. This method requires a standard license. |
string errorMessage = await QueuedTask.Run(() =>
try
var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
//if there is no fabric in the map then bail
if (myParcelFabricLayer == null)
return "There is no fabric in the map.";
var myParcelFabricDataset = myParcelFabricLayer.GetParcelFabric();
catch (Exception ex)
return ex.Message;
return "";
if (!string.IsNullOrEmpty(errorMessage))
MessageBox.Show(errorMessage, "Get Parcel Fabric Dataset from layer.");
try
var myTopology = myParcelFabricDataset.GetParcelTopology();
return ex.Message;
return "";
MessageBox.Show(errorMessage, "Get Parcel Fabric Topology.");
try
FeatureClass myPointsFC = myParcelFabricDataset.GetSystemTable(SystemTableType.Points) as FeatureClass;
FeatureClass myCoonectionsFC = myParcelFabricDataset.GetSystemTable(SystemTableType.Connections) as FeatureClass;
FeatureClass myRecordsFC = myParcelFabricDataset.GetSystemTable(SystemTableType.Records) as FeatureClass;
return ex.Message;
return "";
MessageBox.Show(errorMessage, "Get point, connection, and record feature classes.");
try
string myParcelTypeName = "Tax";
var typeInfo = myParcelFabricDataset.GetParcelTypeInfo();
FeatureClass lineFCType = null;
FeatureClass polyFCType = null;
foreach (var info in typeInfo)
if (info.Name.Equals(myParcelTypeName, StringComparison.CurrentCultureIgnoreCase))
lineFCType = info.LineFeatureTable as FeatureClass;
polyFCType = info.PolygonFeatureTable as FeatureClass;
break;
return ex.Message;
return "";
MessageBox.Show(errorMessage, "Get Parcel Type feature classes.");
