Protected Sub SetSketchSegmentSymbolOptions( _ ByVal options As SegmentSymbolOptions _ )
protected void SetSketchSegmentSymbolOptions( SegmentSymbolOptions options )
Parameters
- options
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.ArgumentException | Symbol options are not valid. See ArcGIS.Desktop.Core.EditingOptions.CanSetSegmentSymbolOptions for details on option settings. |
/// <summary> /// Within the specialization of a MapTool, this method handles activation and deactivation of the tool, allowing customization of sketch segment and vertex symbology when /// the tool becomes active. When the tool is activated, this method customizes the appearance of sketch segments and vertices by updating their symbol options. This includes setting colors, widths, marker types, and other visual properties for both segments and regular unselected vertices. /// </summary> protected override Task OnToolActivateAsync(bool active) { QueuedTask.Run(() => { //Getting the current symbology options of the segment var segmentOptions = GetSketchSegmentSymbolOptions(); //Modifying the primary and secondary color and the width of the segment symbology options var deepPurple = new CIMRGBColor() { R = 75, G = 0, B = 110 }; segmentOptions.PrimaryColor = deepPurple; segmentOptions.Width = 4; segmentOptions.HasSecondaryColor = true; var pink = new CIMRGBColor() { R = 219, G = 48, B = 130 }; segmentOptions.SecondaryColor = pink; //Creating a new vertex symbol options instance with the values you want var vertexOptions = new VertexSymbolOptions(VertexSymbolType.RegularUnselected); var yellow = new CIMRGBColor() { R = 255, G = 215, B = 0 }; var purple = new CIMRGBColor() { R = 148, G = 0, B = 211 }; vertexOptions.AngleRotation = 45; vertexOptions.Color = yellow; vertexOptions.MarkerType = VertexMarkerType.Star; vertexOptions.OutlineColor = purple; vertexOptions.OutlineWidth = 3; vertexOptions.Size = 5; //Setting the value of the segment symbol options SetSketchSegmentSymbolOptions(segmentOptions); //Setting the value of the vertex symbol options of the regular unselected vertices using the vertexOptions instance created above. SetSketchVertexSymbolOptions(VertexSymbolType.RegularUnselected, vertexOptions); }); return base.OnToolActivateAsync(active); }
