ArcGIS.Desktop.Mapping Namespace / GroupLayer Class / GetUseSymbolLayerDrawing Method
Example
    GetUseSymbolLayerDrawing Method (GroupLayer)
    Gets whether the group layer is currently using Symbol Layer Drawing or not. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public ValueTuple<bool,bool> GetUseSymbolLayerDrawing()
    Public Function GetUseSymbolLayerDrawing() As ValueTuple(Of Boolean,Boolean)
    Return Value
    Returns a tuple(useOnLayer, useOnParent). useOnLayer will be true if the feature layer is currently using SLD. useOnParent will be true if a parent group layer is currently using SLD (and useOnLayer will be false).
    Exceptions
    ExceptionDescription
    SLD has not been added to this layer or a parent
    Remarks
    Calling GetUseSymbolLayerDrawing() on a group layer that does not have SLD added or SLD added to a parent group layer will throw an System.InvalidOperationException. Use HasSymbolLayerDrawingAdded to determine if the group layer has SLD added.
    The tuple returns two values (useOnLayer, useOnParent). useOnLayer will always be false for a group layer that participates in a parent group layer using SLD. The parent group layer will control SLD for all participating child group layers and feature layers.
    Example
    Enable/Disable SLD
      await QueuedTask.Run(() =>
        //A layer may have SLD added but is not using it
        //HasSymbolLayerDrawingAdded returns a tuple - to check
        //the layer has SLD (not its parent) check addedOnLayer
        if (featureLayer.HasSymbolLayerDrawingAdded().addedOnLayer)
          //the layer has SLD but is the layer currently using it?
          //GetUseSymbolLayerDrawing returns a tuple - useOnLayer for
          //the layer (and useOnParent for the parent layer)
          if (!featureLayer.GetUseSymbolLayerDrawing().useOnLayer)
            //enable it
            featureLayer.SetUseSymbolLayerDrawing(true);
      //Enable/Disable SLD on a layer parent
      if (await QueuedTask.Run(() => featureLayer.HasSymbolLayerDrawingAdded().addedOnParent))
        //check parent...this can be recursive
        var parent = await GetParentLayerWithSLDAsync(featureLayer.Parent as GroupLayer);
        if (parent != null)
            if (parent.GetUseSymbolLayerDrawing().useOnLayer)
              parent.SetUseSymbolLayerDrawing(true);
      //Recursively get the parent with SLD
      Task<GroupLayer> GetParentLayerWithSLDAsync(GroupLayer groupLayer) =>
          while (groupLayer != null)
            var sld_added = groupLayer.HasSymbolLayerDrawingAdded();
            if (sld_added.addedOnLayer)
              return groupLayer;
            if (!sld_added.addedOnParent)
              break;
            groupLayer = groupLayer.Parent as GroupLayer;
          return null;
    Requirements
