ArcGIS.Desktop.Mapping Namespace / GroupLayer Class / SetUseSymbolLayerDrawing Method
Set to true to use symbol layer drawing
Example
    SetUseSymbolLayerDrawing Method (GroupLayer)
    Sets whether Symbol Layer Drawing will be used on the group layer or not. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetUseSymbolLayerDrawing(
       bool useSLD
    Public Sub SetUseSymbolLayerDrawing( _
       ByVal useSLD As Boolean _
    Parameters
    useSLD
    Exceptions
    ExceptionDescription
    SLD has not been added to this layer or a parent
    SLD is being controlled by a parent group layer
    Remarks
    Calling SetUseSymbolLayerDrawing(useSLD) on a group layer that does not have SLD added, or on a group layer that is part of a parent group layer using SLD, will throw an System.InvalidOperationException. Use HasSymbolLayerDrawingAdded to determine if the group layer has SLD added or participates in a parent group layer with SLD added.
    Example
    Enable/Disable SLD
      await QueuedTask.Run(() =>
        //A layer may have SLD added but is not using it
        //HasSymbolLayerDrawingAdded returns a tuple - to check
        //the layer has SLD (not its parent) check addedOnLayer
        if (featureLayer.HasSymbolLayerDrawingAdded().addedOnLayer)
          //the layer has SLD but is the layer currently using it?
          //GetUseSymbolLayerDrawing returns a tuple - useOnLayer for
          //the layer (and useOnParent for the parent layer)
          if (!featureLayer.GetUseSymbolLayerDrawing().useOnLayer)
            //enable it
            featureLayer.SetUseSymbolLayerDrawing(true);
      //Enable/Disable SLD on a layer parent
      if (await QueuedTask.Run(() => featureLayer.HasSymbolLayerDrawingAdded().addedOnParent))
        //check parent...this can be recursive
        var parent = await GetParentLayerWithSLDAsync(featureLayer.Parent as GroupLayer);
        if (parent != null)
            if (parent.GetUseSymbolLayerDrawing().useOnLayer)
              parent.SetUseSymbolLayerDrawing(true);
      //Recursively get the parent with SLD
      Task<GroupLayer> GetParentLayerWithSLDAsync(GroupLayer groupLayer) =>
          while (groupLayer != null)
            var sld_added = groupLayer.HasSymbolLayerDrawingAdded();
            if (sld_added.addedOnLayer)
              return groupLayer;
            if (!sld_added.addedOnParent)
              break;
            groupLayer = groupLayer.Parent as GroupLayer;
          return null;
    Requirements
