ArcGIS.Core.CIM Namespace / CIMNetworkAttributeParameterDefinitionValue Class
Properties Methods Events
    CIMNetworkAttributeParameterDefinitionValue Class Members
    The following tables list the members exposed by CIMNetworkAttributeParameterDefinitionValue.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether this is a restriction usage type network parameter.
    Public Property Gets or sets the network attribute name.
    Public Property Gets or sets the network parameter name.
    Public Property Gets or sets the value. The type of the value should correspond with the ValueType property or be null.
    Public Property Gets or sets the value type. Supports: Short, Long, Float, Double, Date, String, Bool.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMNetworkAttributeParameterDefinitionValue.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMNetworkAttributeParameterDefinitionValue with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMNetworkAttributeParameterDefinitionValue and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
