ArcGIS.Core.Data.NetworkDiagrams Namespace / ReshapeEdgesDiagramLayoutParameters Class / ThresholdAngle Property
    ThresholdAngle Property (ReshapeEdgesDiagramLayoutParameters)
    Threshold angle when executing the ReshapeEdgesDiagramLayoutParameters.Operation.ReduceVerticesByAngle operation.
    Syntax
    Public Property ThresholdAngle As Double
    public double ThresholdAngle {get; set;}
    Remarks
    The angle formed by the incident segments over which the vertex related to these segments is reduced. The wider the angle, the fewer vertices are reduced. The default is 160 degrees.
    Requirements
