ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / EllipticArcBuilderEx Constructor / EllipticArcBuilderEx Constructor(MapPoint,Double,Double,Double,ArcOrientation,MinorOrMajor,SpatialReference)
The point from which the arc starts.
The length of the chord connecting start point to the end point of the arc. If negative, then the absolute value is used. Cannot be equal to zero.
The angle in radians of the chord connecting the start point to the end point of the arc.
The radius of the embedded circle.
The orientation of the arc, clockwise or counterclockwise.
Indicates whether the arc is a minor or major arc. A minor arc is an arc such that the central angle is less than PI radians.
(Optional) The spatial reference of the arc. The default value is null. The spatial reference of the start point is ignored.
    Creates a new instance of the EllipticArcBuilderEx class. The new instance will be a circular arc.
    Syntax
    Parameters
    startPt
    chordLength
    chordBearing
    radius
    orientation
    minorOrMajor
    spatialReference
    Exceptions
    ExceptionDescription
    startPt is null or empty.
    chordLength, chordBearing or radius is NaN.
    chordLength equals zero or is greater than 2 * radius.
    Requirements
