ArcGIS.Core.Geometry Namespace / EllipticArcBuilderEx Class / EllipticArcBuilderEx Constructor / EllipticArcBuilderEx Constructor(MapPoint,MapPoint,Double,Double,Double,MinorOrMajor,ArcOrientation,SpatialReference)
The start point of the elliptic arc.
The end point of the elliptic arc.
The length of the semi-major axis.
The ratio of the length of the semi-minor axis to the length of the semi-major axis. The absolute value must be <= 1.
The angle in radians by which the ellipse is rotated from the X-axis. A positive value corresponds to counterclockwise rotation.
The enumeration value indicating whether the arc is a minor or major arc. A minor arc is an arc such that the central angle is less than PI radians.
The value indicating if the arc is oriented clockwise or counterclockwise.
(Optional) The spatial reference. The default value is null. The spatial references of the start and end points are ignored.
Example
    Creates a new instance of the EllipticArcBuilderEx class. The new instance will be an elliptic arc.
    Syntax
    Parameters
    startPt
    endPt
    semiMajorAxis
    minorMajorRatio
    rotationAngle
    minorOrMajor
    orientation
    spatialReference
    Exceptions
    ExceptionDescription
    startPt or endPt is null or empty.
    semiMajorAxis, minorMajorRatio or rotationAngle is NaN.
    An elliptic arc construction operation was given invalid axes. The absolute value of minorMajorRatio is > 1.
    An elliptic arc construction operation was given invalid axes. It is not possible to construct the elliptic arc with the given axes.
    The start and end points cannot have the same xy-coordinates for this method.
    Remarks
    If minorMajorRatio is equal to one, then a circular arc will be created and the rotation angle will be equal to zero.
    Example
    Create Ellipse Text Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D center = new Coordinate2D(4.5, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45, ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
      //Set symbology, create and add element to layout
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                            ColorFactory.Instance.BlueRGB, 10, "Arial", "Regular");
      string text = "Ellipse, ellipse, ellipse";
      GraphicElement ge = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PolygonParagraph, poly, sym, text, "New Ellipse Text", false);
    Create Predefined Shape Graphic Element 3
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                            ColorFactory.Instance.GreenRGB, 2.0, SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                       ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical, outline);
      var ge = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
        layout, PredefinedShape.Ellipse, poly.Extent.Center, 0, 0, ellipseSym,
        "New Ellipse2", false, new ElementInfo() { Anchor = Anchor.TopRightCorner });
    Requirements
