public static Polygon FromJson( string jsonString )
Public Shared Function FromJson( _ ByVal jsonString As String _ ) As Polygon
Parameters
- jsonString
- JSON string representation of Polygon.
Return Value
A Polygon.
| Exception | Description |
| System.ArgumentNullException | The jsonString is empty or null. |
| ArcGIS.Core.Geometry.Exceptions.GeometryObjectException | The JSON string is invalid or does not represent a polygon string. |
// Use a builder convenience method or use a builder constructor.
MapPoint point = MapPointBuilderEx.CreateMapPoint(10, 20);
List<Coordinate2D> coords = new List<Coordinate2D>() { new Coordinate2D(50, 60), new Coordinate2D(-120, -70), new Coordinate2D(40, 60) };
Multipoint multipointNew = MultipointBuilderEx.CreateMultipoint(coords, SpatialReferences.WebMercator);
Polyline polylineNew = PolylineBuilderEx.CreatePolyline(coords);
string json = "{\"rings\":[[[0,0],[0,1],[1,1],[1,0],[0,0]],[[3,0],[3,1],[4,1],[4,0],[3,0]]]}";
Polygon polygonNew = PolygonBuilderEx.FromJson(json);
var geometries = new List<Geometry>() { point, multipoint, polyline, polygon };
// Builder convenience methods don't need to run on the MCT.
var bag = GeometryBagBuilderEx.CreateGeometryBag(geometries, SpatialReferences.WGS84);
var builder = new GeometryBagBuilderEx(geometries, SpatialReferences.WGS84);
// do something with the builder
bag = builder.ToGeometry();
var builder = new GeometryBagBuilderEx(SpatialReferences.WGS84);
builder.AddGeometries(geometries);
GeometryBag geomBag = builder.ToGeometry();
// geomBag.PartCount == 4 (point, multipoint, polyline, polygon)
geometries = new List<Geometry>() { point, polyline };
builder.InsertGeometries(1, geometries);
// builder.GeometryCount == 6
// geomBag.PartCount == 6 (point, point, polyline, multipoint, polyline, polygon)
// build a polygon
string json = "{\"hasZ\":true,\"rings\":[[[0,0,0],[0,1,0],[1,1,0],[1,0,0],[0,0,0]]],\"spatialReference\":{\"wkid\":4326}}";
// extrude the polygon by an offset to create a multipatch
multipatch = GeometryEngine.Instance.ConstructMultipatchExtrude(polygon, 2);
// a different polygon
json = "{\"hasZ\":true,\"rings\":[[[0,0,1],[0,1,2],[1,1,3],[1,0,4],[0,0,1]]],\"spatialReference\":{\"wkid\":4326}}";
polygon = PolygonBuilderEx.FromJson(json);
// extrude between z values to create a multipatch
multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeFromToZ(polygon, -10, 20);
// extrude along the axis defined by the coordinate to create a multipatch
Coordinate3D coord = new Coordinate3D(10, 18, -10);
multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeAlongVector3D(polygon, coord);
// build a polyline
json = "{\"hasZ\":true,\"paths\":[[[400,800,1000],[800,1400,1500],[1200,800,2000],[1800,1800,2500],[2200,800,3000]]],\"spatialReference\":{\"wkid\":3857}}";
Polyline polylineNew = PolylineBuilderEx.FromJson(json);
// extrude to a specific z value to create a multipatch
multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeToZ(polyline, 500);
Coordinate3D fromCoord = new Coordinate3D(50, 50, -500);
Coordinate3D toCoord = new Coordinate3D(200, 50, 1000);
// extrude between two coordinates to create a multipatch
multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeAlongLine(polyline, fromCoord, toCoord);
// MapPoint
string inputString =
"{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}";
Geometry geometryFromJson = GeometryEngine.Instance.ImportFromJson(
JsonImportFlags.JsonImportDefaults, inputString);
MapPoint importPoint = geometryFromJson as MapPoint;
// importPoint = 1, 2
// importPoint.SpatialReference.WKid = 4326
// use the MapPointBuilderEx convenience method
MapPoint importPoint2 = MapPointBuilderEx.FromJson(inputString);
// importPoint2 = 1, 2
// impointPoint2.SpatialReference.Wkid = 4326
string outputString = GeometryEngine.Instance.ExportToJson(
JsonExportFlags.JsonExportDefaults, importPoint);
// outputString =
// "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}"
string outputString2 = importPoint.ToJson();
inputString =
"{\"spatialReference\":{\"wkid\":4326},\"z\":3,\"m\":4,\"x\":1,\"y\":2}";
importPoint = GeometryEngine.Instance.ImportFromJson(
JsonImportFlags.JsonImportDefaults, inputString) as MapPoint;
// importPoint.HasM = true
// importPoint.HasZ = true
// importPoint.X = 1
// importPoint.Y = 2
// importPoint.M = 4
// importPoint.Z = 3
// export to json - skip spatial reference
JsonExportFlags.JsonExportSkipCRS, importPoint);
// outputString = "{\"x\":1,\"y\":2,\"z\":3,\"m\":4}"
// export from mappoint, skipping the sr - same as GeometryEngine.Instance.ExportToJson w JsonExportFlags.JsonExportSkipCRS
outputString2 = importPoint.ToJson(true);
// Multipoint
new Coordinate2D(100, 200),
new Coordinate2D(201, 300),
new Coordinate2D(301, 400),
new Coordinate2D(401, 500)
Multipoint multipointFromCoords = MultipointBuilderEx.CreateMultipoint(
inputString =
"{\"points\":[[100,200],[201,300],[301,400],[401,500]],\"spatialReference\":{\"wkid\":3857}}";
Multipoint importMultipoint =
JsonImportFlags.JsonImportDefaults, inputString) as Multipoint;
// importMultipoint.IsEqual(multipoint) = true
ReadOnlyPointCollection pointsFromMultipoint = importMultipoint.Points;
// points.Count = 4
// points[0] = 100, 200
// points[1] = 201, 300
// points[2] = 301, 400
// points[3] = 401, 500
// use the MultipointbuilderEx convenience method
Multipoint importMultipoint2 = MultipointBuilderEx.FromJson(inputString);
// importMultipoint2.IsEqual(multipoint) = true
// export to json
JsonExportFlags.JsonExportDefaults, multipointFromCoords);
// outputString = inputString
// or use the multipoint itself
outputString2 = multipointFromCoords.ToJson();
// Polyline
Polyline polylineFromCoords = PolylineBuilderEx.CreatePolyline(
// export without the spatial reference
JsonExportFlags.JsonExportSkipCRS, polylineFromCoords);
// import
geometry = GeometryEngine.Instance.ImportFromJson(
JsonImportFlags.JsonImportDefaults, outputString);
Polyline importPolyline = geometryFromJson as Polyline;
// importPolyline.SpatialReference = null
pointsFromMultipoint = importPolyline.Points;
// points.Count = 4
// use the polylineBuilderEx convenience method
Polyline importPolyline2 = PolylineBuilderEx.FromJson(outputString);
// importPolyline2 = importPolyline
outputString2 = importPolyline2.ToJson();
// outputString2 = outputString
// Polygon
Polygon polygonFromCoords = PolygonBuilderEx.CreatePolygon(
JsonExportFlags.JsonExportSkipCRS, polygonFromCoords);
// import
Polygon importPolygon = geometry as Polygon;
// importPolygon.SpatialReference = null
pointsFromMultipoint = importPolygon.Points;
// points.Count = 5
// polygonBuilderEx convenience method
Polygon importPolyon2 = PolygonBuilderEx.FromJson(outputString);
// importPolygon2 = importPolygon
// export from the polygon
outputString2 = importPolyon2.ToJson(true);
// Empty polygon
polygon = PolygonBuilderEx.CreatePolygon(SpatialReferences.WebMercator);
JsonExportFlags.JsonExportDefaults, polygon);
importPolygon = GeometryEngine.Instance.ImportFromJson(
JsonImportFlags.JsonImportDefaults, outputString) as Polygon;
// importPolygon.IsEmpty = true
// importPolygon.SpatialReference.Wkid = 3857
var g1 = PolygonBuilderEx.FromJson("{\"rings\": [ [ [0, 0], [10, 0], [10, 10], [0, 10] ] ] }");
double d = GeometryEngine.Instance.Area(g1);
// d = -100.0 //negative due to wrong ring orientation
d = GeometryEngine.Instance.Area(GeometryEngine.Instance.SimplifyAsFeature(g1));
// d = 100.0 // feature has been simplifed; ring orientation is correct
string json = "{\"hasM\":true,\"rings\":[[[-3000,-2000,10],[-2000,-2000,15],[-1000,-2000,20],[0,-2000,0],[1000,-2000,-20],[2000,-2000,-30],[3000,-2000,10],[4000,-2000,5]]],\"spatialReference\":{\"wkid\":3857}}";
GeometryEngine.Instance.GetMinMaxM(polygon, out double minM, out double maxM);
// minM = -30
// maxM = 20
json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,10],[-2000,-2000,null],[-1000,-2000,null]]]}";
polyline = PolylineBuilderEx.FromJson(json);
GeometryEngine.Instance.GetMinMaxM(polyline, out minM, out maxM);
// minM = 10
// maxM = 10
json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,null],[-2000,-2000,null],[-1000,-2000,null]]]}";
// minM = double.Nan
// maxM = double.Nan
string json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,1],[-2000,-2000,2],[-1000,-2000,3],[0,-2000,null],[1000,-2000,4],[2000,-2000,5],[3000,-2000,10],[4000,-2000,11],[5000,-2000,12],[6000,-2000,13],[7000,-2000,14]]],\"spatialReference\":{\"wkid\":3857}}";
Polyline outPolyline = GeometryEngine.Instance.SetMsAsDistance(polyline, AsRatioOrLength.AsLength) as Polyline;
// The xy-coordinates don't change.
// The M-values of the vertices in outPolyline are (x, y, m):
// { 0, 1000, 2000, 3000, 4000, 5000, 6000, 7000, 8000, 9000, 10000 }
json = "{\"hasM\":true,\"rings\":[[[0,0],[0,3000],[4000,3000],[4000,0],[0,0]]],\"spatialReference\":{\"wkid\":3857}}";
Polygon outPolygon = GeometryEngine.Instance.SetMsAsDistance(polygon, AsRatioOrLength.AsLength) as Polygon;
// The M-values of the vertices in outPolygon are (x, y, m): { 0, 3000, 7000, 10000, 14000 };
var result = GeometryEngine.Instance.Area(g1); // result = -100.0 - negative due to wrong ring orientation
// simplify it
var result2 = GeometryEngine.Instance.Area(GeometryEngine.Instance.SimplifyAsFeature(g1, true));
// result2 = 100.0 - positive due to correct ring orientation (clockwise)
