ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / PolylineBuilderEx Constructor / PolylineBuilderEx Constructor(IEnumerable<MapPoint>,AttributeFlags,SpatialReference)
Points for the first ring. Line segments are created from the points.
AttributeFlags to set the HasZ, HasM and HasID attributes. If no attributes should be set, pass AttributeFlags.None. If all attributes should be set, pass AttributeFlags.AllAttributes. Use the bitwise OR operator to set two attributes. For example, to set HasZ = true and HasM = true, pass AttributeFlags.HasZ | AttributeFlags.HasM.
(Optional) The SpatialReference. The default value is null. The spatial reference of each point is ignored.
    Creates a new instance of the PolylineBuilderEx class.
    Syntax
    Parameters
    points
    attributes
    spatialReference
    Exceptions
    ExceptionDescription
    The input mapPoint enumeration is null.
    Requirements
