ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / PolylineBuilderEx Constructor / PolylineBuilderEx Constructor(IEnumerable<Segment>,AttributeFlags,SpatialReference)
Segments for the first part.
AttributeFlags to set the HasZ, HasM and HasID attributes. If no attributes should be set, pass AttributeFlags.None. If all attributes should be set, pass AttributeFlags.AllAttributes. Use the bitwise OR operator to set two attributes. For example, to set HasZ = true and HasM = true, pass AttributeFlags.HasZ | AttributeFlags.HasM.
(Optional) The SpatialReference. The default value is null.
    Creates a new instance of the PolylineBuilderEx class.
    Syntax
    Parameters
    segments
    attributes
    spatialReference
    Exceptions
    ExceptionDescription
    The input segment enumeration is null.
    Remarks
    The spatial reference of each segment is ignored.
    Requirements
