ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / PolylineBuilderEx Constructor / PolylineBuilderEx Constructor(Segment,AttributeFlags,SpatialReference)
The segment for the first part.
AttributeFlags to set the HasZ, HasM and HasID attributes. If no attributes should be set, pass AttributeFlags.None. If all attributes should be set, pass AttributeFlags.AllAttributes. Use the bitwise OR operator to set two attributes. For example, to set HasZ = true and HasM = true, pass AttributeFlags.HasZ | AttributeFlags.HasM.
(Optional) The SpatialReference. The default value is null.
    Creates a new instance of the PolylineBuilderEx class.
    Syntax
    Public Function New( _
       ByVal segment As Segment, _
       ByVal attributes As AttributeFlags, _
       Optional ByVal spatialReference As SpatialReference _
    Parameters
    segment
    attributes
    spatialReference
    Exceptions
    ExceptionDescription
    The input segment is null.
    Remarks
    The spatial reference of the segment is ignored.
    Requirements
