Composite_ElevationSource Property
Supports browsing for web layers and datasets that can be used to define the elevation surface of a globe. As a composite filter, the default
filter allows you to browse for anything that is supported, but focused filters are also available to browse just for images services, for example,
that you want to define the ground.
Syntax
Public Shared ReadOnly Property Composite_ElevationSource As String
public static string Composite_ElevationSource {get;}
Requirements
