ArcGIS.Desktop.Editing Namespace / EditOperation Class / Create Method / Create(MapMember,Dictionary<String,Object>) Method
The layer or standalone table to create the new row in.
The attributes to assign to the new row.
Example
    Creates a new row with the given attributes.
    Syntax
    Parameters
    mapMember
    values
    Return Value
    A RowToken object that represents the row to be created.
    Example
    Create feature from a modified inspector
    // Creates a new feature by copying and optionally modifying the attributes of an existing feature using an inspector.
    await QueuedTask.Run(() =>
          // Create an inspector and load a feature
          // The inspector is used to modify the attributes of the feature before creating it
          var insp = new Inspector();
          insp.Load(featureLayer, objectId);
          // modify attributes if necessary
          // insp["Field1"] = newValue;
          //Create new feature from an existing inspector (copying the feature)
          var createOp = new EditOperation() { Name = "Create from insp" };
          createOp.Create(insp.MapMember, insp.ToDictionary(a => a.FieldName, a => a.CurrentValue));
          if (!createOp.IsEmpty)
            var result = createOp.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Create features from a CSV file
    // Creates new point features in the specified feature layer using data from a CSV source.
    var csvData = new List<(double X, double Y, double StopOrder, double FacilityID)>();
    //Run on MCT
      //Create the edit operation
      var createOperation = new ArcGIS.Desktop.Editing.EditOperation() { Name = "Generate points", SelectNewFeatures = false };
      // determine the shape field name - it may not be 'Shape'
      string shapeField = featureLayer.GetFeatureClass().GetDefinition().GetShapeField();
      //Loop through csv data
      foreach (var item in csvData)
        //Create the point geometry
        ArcGIS.Core.Geometry.MapPoint newMapPoint =
            ArcGIS.Core.Geometry.MapPointBuilderEx.CreateMapPoint(item.X, item.Y);
        // include the attributes via a dictionary
        var atts = new Dictionary<string, object>
            { "StopOrder", item.StopOrder },
            { "FacilityID", item.FacilityID },
            { shapeField, newMapPoint }
        // queue feature creation
        createOperation.Create(featureLayer, atts);
      // execute the edit (feature creation) operation
      if (createOperation.IsEmpty)
        return createOperation.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
      else
        return false;
    Edit Operation Duplicate Features
    // Duplicates a feature in a feature layer and modifies its geometry.
        var duplicateFeatures = new EditOperation() { Name = "Duplicate Features" };
        //Duplicate with an X and Y offset of 500 map units
        //Execute to execute the operation
        //Must be called within QueuedTask.Run
        var insp2 = new Inspector();
        insp2.Load(featureLayer, objectId);
        var geom = insp2["SHAPE"] as Geometry;
        var rtoken = duplicateFeatures.Create(insp2.MapMember, insp2.ToDictionary(a => a.FieldName, a => a.CurrentValue));
        if (!duplicateFeatures.IsEmpty)
          if (duplicateFeatures.Execute())//Execute and ExecuteAsync will return true if the operation was successful and false if not
            var modifyOp = duplicateFeatures.CreateChainedOperation();
            modifyOp.Modify(featureLayer, (long)rtoken.ObjectID, GeometryEngine.Instance.Move(geom, 500.0, 500.0));
            if (!modifyOp.IsEmpty)
              var result = modifyOp.Execute();
    Create a new Relationship and New Entities 2
      var mv = MapView.Active;
      var createRel = await QueuedTask.Run(() =>
        //This example uses a KnowledgeGraphRelationshipDescription
        var edit_op = new EditOperation()
          Name = "Create entities and a relationship using a KG relate desc",
          SelectNewFeatures = true
        //We are just going to use mapmembers in this example
        //we could equally use feature classes/tables
        var kg_layer = mv.Map.GetLayersAsFlattenedList()?
                      .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>().First();
        //From the KG Layer get the relevant child feature layer(s) and/or standalone
        //table(s)
        var org_fl = kg_layer.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                        .First(child_layer => child_layer.Name == "Organization");
        var person_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "Person");
        var rel_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "HasEmployee");
        var attribs = new Dictionary<string, object>();
        //New Organization
        attribs["Name"] = "Acme Ltd.";
        attribs["Description"] = "Specializes in household items";
        attribs["SHAPE"] = mv.Extent.Center;//whatever is its location
        //Add it to the operation - we need the rowtoken
        var rowtoken_org = edit_op.Create(org_fl, attribs);
        attribs.Clear();//we are going to re-use the dictionary
        //New Person
        attribs["Name"] = "Bob";
        attribs["Age"] = "41";
        attribs["Skills"] = "Plumbing, Framing, Flooring";
        var rowtoken_person = edit_op.Create(person_stbl, attribs);
        attribs.Clear();
        //Create the new relationship using a KnowledgeGraphRelationshipDescription
        //Row handles act as the placeholders for the TO BE created new entities that will
        //be related
        var src_row_handle = new RowHandle(rowtoken_org);
        var dest_row_handle = new RowHandle(rowtoken_person);
        //Add any extra attribute information for the relation as needed
        attribs["StartDate"] = new DateTimeOffset(DateTime.Now);
        var rel_desc = new KnowledgeGraphRelationshipDescription(
                                    src_row_handle, dest_row_handle, attribs);
        //Add the relate description to the edit operation
        edit_op.Create(rel_stbl, rel_desc);
        //Execute the create of the entities and relationship
        return edit_op.Execute();
    Create a record in a separate table in the Map within Row Events
    // attach an event handler to receive notifications when a new row is created in the
    // associated table of the first feature layer found in the active map. Use this method to enable custom logic in
    // response to row creation events within your ArcGIS Pro add-in.
    // subscribe to the RowCreatedEvent
    Table table = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable();
    RowCreatedEvent.Subscribe(rowChangedEventArgs =>
        // RowEvent callbacks are always called on the QueuedTask so there is no need
        // to wrap your code within a QueuedTask.Run lambda.
        // get the edit operation
        var parentEditOp = rowChangedEventArgs.Operation;
        // set up some attributes
          { "Layer", "Parcels" },
          { "Description", "objectId: " + rowChangedEventArgs.Row.GetObjectID().ToString() + " " + DateTime.Now.ToShortTimeString() }
        //create a record in an audit table
        var sTable = MapView.Active.Map.FindStandaloneTables("EditHistory")[0];
        var table = sTable.GetTable();
        parentEditOp.Create(table, attribs);
      }, table);
    Create a record in a separate table within Row Events
    // Attach an event handler to the <see cref="ArcGIS.Desktop.Editing.Events.RowCreatedEvent"/> for the table associated with the first <see cref="ArcGIS.Desktop.Mapping.FeatureLayer"/> in the active map. Use this method to monitor when new rows are created
    // in that table, enabling custom logic to be executed in response to record creation events.
    Table firstTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable();
      // update a separate table not in the map when a row is created
      // You MUST use the ArcGIS.Core.Data API to edit the table. Do NOT
      // use a new edit operation in the RowEvent callbacks
      try
        // update Notes table with information about the new feature
        using var geoDatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(Project.Current.DefaultGeodatabasePath)));
        using var table = geoDatabase.OpenDataset<Table>("Notes");
      catch (Exception e)
        throw new Exception($@"Error in OnRowCreated for objectId: {rowChangedEventArgs.Row.GetObjectID()} : {e}");
    }, firstTable);
    Create a Document Record 2
        using (var kg_for_doc = kgLayer.GetDatastore())
          var propInfo = kg_for_doc.GetPropertyNameInfo();
          if (!propInfo.SupportsDocuments)
            return false;
            Name = "Create Document Example",
          var doc_entity_name = propInfo.DocumentTypeName;
          var hasdoc_rel_name = GetHasDocumentTypeName(kg.GetDataModel());
          //Document can also be FeatureClass
          var doc_tbl = kg_for_doc.OpenDataset<Table>(doc_entity_name);
          var doc_rel_tbl = kg_for_doc.OpenDataset<Table>(hasdoc_rel_name);
          //This is the document to be added...file, image, resource, etc.
          var doc_url = @"E:\Data\Temp\HelloWorld.txt";
          // create the KnowledgeGraphDocumentDescription
          var kgDocDesc = new KnowledgeGraphDocumentDescription(doc_url);
          // if there is a geometry use the following ctor
          // var kgDocDesc = new KnowledgeGraphDocumentDescription(doc_url, doc_location);
          // if you have additional custom attributes
          //var customDocAtts = new Dictionary<string, object>();
          //customDocAtts.Add("custom_attrib", "Foo");
          //customDocAtts.Add("custom_attrib2", "Bar");
          //var kgDocDesc = new KnowledgeGraphDocumentDescription(url, null, customDocAtts);
          // add additional properties if required
          kgDocDesc.Keywords = @"text,file,example";
          // The Create method will auto-populate the Url, Name, FileExtension and contentType fields of the document row
          // from the path supplied.
          var rowToken = edit_op.Create(doc_tbl, kgDocDesc);
          //Get the entity whose document this is...
          var org_fc = kg_for_doc.OpenDataset<FeatureClass>("Organization");
          var qf = new ArcGIS.Core.Data.QueryFilter()
            WhereClause = "name = 'Acme'",
            SubFields = "*"
          var origin_org_id = Guid.Empty;
          using (var rc = org_fc.Search(qf))
            if (!rc.MoveNext())
              return false;
            origin_org_id = rc.Current.GetGlobalID();//For the relate
          // set up the row handles
          var originHandle = new RowHandle(org_fc, origin_org_id);    // entity
          var destinationHandle = new RowHandle(rowToken);            // document
          // create the KnowledgeGraphRelationshipDescription
          var rd = new KnowledgeGraphRelationshipDescription(originHandle, destinationHandle);
          // if you have additional custom attributes for the "HasDocument" relationship
          //var customHasDocAtts = new Dictionary<string, object>();
          //customHasDocAtts.Add("custom_attrib", "Foo");
          //customHasDocAtts.Add("custom_attrib2", "Bar");
          //var rd = new KnowledgeGraphRelationshipDescription(originHandle, destinationHandle, customHasDocAtts);
          // create the relate record using the same edit operation
          edit_op.Create(doc_rel_tbl, rd);
          //Call execute to create all the entities and relationship rows _together_
    Requirements
