ArcGIS.Desktop.Editing Namespace / EditOperation Class / Reshape Method / Reshape(SelectionSet,Geometry) Method
The set of features to reshape.
Reshape the features with this geometry.
Example
    Reshape a set of features with a geometry.
    Syntax
    Public Overloads Sub Reshape( _
       ByVal features As SelectionSet, _
       ByVal reshapeGeometry As Geometry _
    public void Reshape(
       SelectionSet features,
       Geometry reshapeGeometry
    Parameters
    features
    reshapeGeometry
    Example
    Edit Operation Reshape Features
    // Reshapes the specified feature in the given feature layer.
    await QueuedTask.Run(() =>
        var reshapeFeatures = new EditOperation() { Name = "Reshape Features" };
        reshapeFeatures.Reshape(featureLayer, objectId, modifyLine);
        //Reshape a set of features that intersect some geometry....
        reshapeFeatures.Reshape(MapView.Active.GetFeatures(modifyLine), modifyLine);
        //Execute to execute the operation
        //Must be called within QueuedTask.Run
        if (!reshapeFeatures.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = reshapeFeatures.Execute();
          //or use async flavor
          //await reshapeFeatures.ExecuteAsync();
    Requirements
