ArcGIS.Desktop.Editing Namespace / EditOperation Class / Transform Method / Transform(SelectionSet,TransformMethod) Method
The set of features to transform.
The transformation method to use.
Example
    Transform a set of features.
    Syntax
    Public Overloads Sub Transform( _
       ByVal features As SelectionSet, _
       ByVal transformMethod As TransformMethod _
    Parameters
    features
    transformMethod
    Exceptions
    ExceptionDescription
    Transformation method cannot be null
    Invalid transformation method
    Example
    Edit Operation Transform Features
    // Transforms features from a source layer to a target layer using a specified transformation method.
    await QueuedTask.Run(() =>
        //Transform features using EditOperation.Transform overloads
        var transformFeatures = new EditOperation() { Name = "Transform Features" };
        //Transform a selected set of features
        ////Perform an affine transformation
        //transformFeatures.TransformAffine(featureLayer, linkLayer);
        var affine_transform = new TransformByLinkLayer()
          LinkLayer = linkLayer,
          TransformType = TransformMethodType.Affine //TransformMethodType.Similarity
        transformFeatures.Transform(MapView.Active.GetFeatures(polygon), affine_transform);
        transformFeatures.Transform(featureLayer, affine_transform);
        //Execute to execute the operation
        //Must be called within QueuedTask.Run
        if (!transformFeatures.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = transformFeatures.Execute();
          //or use async flavor
          //await transformFeatures.ExecuteAsync();
    Requirements
