ArcGIS.Desktop.Editing Namespace / ElevationCapturing Class / QueryElevationSurfaceLayers Method / QueryElevationSurfaceLayers(Map) Method
the map for which elevation surface layers are requested
    Obtains the usable elevation surface layers that are stored in the specified map.
    Syntax
    Public Overloads Shared Function QueryElevationSurfaceLayers( _
       ByVal map As Map _
    ) As IEnumerable(Of ElevationSurfaceLayer)
    public static IEnumerable<ElevationSurfaceLayer> QueryElevationSurfaceLayers(
       Map map
    Parameters
    map
    Return Value
    A collection of ElevationSurfaceLayer, empty if there are no elevation surface layers in the map
    Exceptions
    ExceptionDescription
    if map is null
    Remarks
    An elevation surface layer is considered usable if it is visible and has at least one elevation source layer.
    Requirements
