ArcGIS.Desktop.Editing.Templates Namespace / EditingRowTemplate Class
Members Example
    Defines how a new row is created for a particular MapMember.
    Object Model
    EditingRowTemplate ClassCIMEditingTemplate ClassCIMSymbolReference ClassReadOnlyToolOptions ClassInspector ClassLayer ClassMap ClassMapMember ClassStandaloneTable Class
    Syntax
    Remarks
    This implementation of EditingTemplate defines the attributes necessary to create a row within a single MapMember.
    Example
    Find edit template by name on a layer
    // Finds and retrieves specific editing templates by name from layers in the active map.
    await QueuedTask.Run(() =>
      var mainTemplate = activeMap.FindLayers("main").FirstOrDefault()?.GetTemplate("Distribution");
      var mhTemplate = activeMap.FindLayers("Manhole").FirstOrDefault()?.GetTemplate("Active");
    Find table templates belonging to a standalone table
    // retrieve editing templates associated with standalone tables in the active map.
      //Get a particular table template
      var tableTemplate = activeMap.FindStandaloneTables("Address Points").FirstOrDefault()?.GetTemplate("Residences");
      //Get all the templates of a standalone table
      var ownersTableTemplates = activeMap.FindStandaloneTables("Owners").FirstOrDefault()?.GetTemplates();
      var statisticsTableTemplates = activeMap.GetStandaloneTablesAsFlattenedList().First(l => l.Name.Equals("Trading Statistics")).GetTemplates();
    Change Default Edit tool for a template
            var templateName = "Distribution"; // name of the template to update
            var toolDamlPlugInID = "esri_editing_SketchTwoPointLineTool"; // DAML ID of the tool to set as default
            var toolContentGUID = "e2096d13-b437-4bc1-94ea-4494c3260f72"; // Example GUID, replace with actual GUID from DAML
        // retrieve the edit template form the layer by name
            var template = featureLayer?.GetTemplate(templateName) as EditingTemplate;
            // get the definition of the layer
            var layerDef = featureLayer?.GetDefinition() as CIMFeatureLayer;
            if (template == null || layerDef == null)
              return;
            if (template.DefaultToolID != toolDamlPlugInID)
              bool updateLayerDef = false;
              if (layerDef.AutoGenerateFeatureTemplates)
                layerDef.AutoGenerateFeatureTemplates = false;
                updateLayerDef = true;
              // retrieve the CIM edit template definition
              var templateDef = template.GetDefinition();
              // assign the GUID from the tool DAML definition, for example
              // <tool id="TestConstructionTool_SampleSDKTool" categoryRefID="esri_editing_construction_polyline" ….>
              //   <tooltip heading="">Tooltip text<disabledText /></tooltip>
              //   <content guid="e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea" />
              // </tool>
              // then the toolContentGUID would be "e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea"
              //templateDef.ToolProgID = toolContentGUID;
              templateDef.DefaultToolGUID = toolContentGUID;
              // set the definition back to
              template.SetDefinition(templateDef);
              // update the layer definition too
              if (updateLayerDef)
                featureLayer.SetDefinition(layerDef);
    Create New Template using layer.CreateTemplate
        var newFieldValues = new object[] { "Value1", 123, DateTime.Now };
        // Creates a new editing template for the specified feature layer with the provided field values.
        var insp = new Inspector();
        insp.LoadSchema(featureLayer);
        insp["Field1"] = newFieldValues[0];
        insp["Field2"] = newFieldValues[1];
        insp["Field3"] = newFieldValues[2];
        var tags = new[] { "Polygon", "tag1", "tag2" };
        // set defaultTool using a daml-id
        string defaultTool = "esri_editing_SketchCirclePolygonTool";
        // tool filter is the tools to filter OUT
        var toolFilter = new[] { "esri_editing_SketchTracePolygonTool" };
        // create a new template
        var newTemplate = featureLayer.CreateTemplate("My new template", "description", insp, defaultTool, tags, toolFilter);
    Create New Table Template using table.CreateTemplate
    // Creates new table templates for the specified standalone table.
      var table = activeMap.GetStandaloneTablesAsFlattenedList().FirstOrDefault();
      var tableTemplate = table.GetTemplate("Template1");
      var definition = tableTemplate.GetDefinition();
      definition.Description = "New definition";
      definition.Name = "New name";
      //Create new table template using this definition
      table.CreateTemplate(definition);
      //You can also create a new table template using this extension method. You can use this method the same way you use the layer.CreateTemplate method.
      table.CreateTemplate("New template name", "Template description", tags: ["tag 1", "tag 2"]);
    Inheritance Hierarchy
    Requirements
