ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetworkExtensions Class / DisableControllerInEditOperation Method
The SubnetworkManager instance used to disable a controller.
Corresponds to the feature to be disabled as a SubnetworkController.
Example
    Disables a feature corresponding to device from being a SubnetworkController. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Sub DisableControllerInEditOperation( _
       ByVal subnetworkManager As SubnetworkManager, _
       ByVal device As Element _
    public static void DisableControllerInEditOperation(
       SubnetworkManager subnetworkManager,
       Element device
    Parameters
    subnetworkManager
    device
    Exceptions
    ExceptionDescription
    The active ArcGIS.Desktop.Mapping.MapView is unavailable.
    -or-
    The ArcGIS.Desktop.Mapping.UtilityNetworkLayer is unavailable.
    A geodatabase-related exception has occurred.
    Remarks
    • This routine generates its own editing transaction and therefore cannot be wrapped inside a separate transaction.
    • If this operation is successful, it will create an edit operation on the Pro undo/redo stack, invalidate the affected layers and cause the ArcGIS.Desktop.Mapping.MapView to redraw. When writing a CoreHost application, use SubnetworkManager.DisableController.
    • If all subnetwork controllers are deleted from a subnetwork, the subnetwork moves to the SubnetworkStates.DirtyAndDeleted state.
    • If this operation is successful, it will invalidate the affected layers and cause the ArcGIS.Desktop.Mapping.MapView to redraw.
    • The input element, device must specify the terminal.
    Example
    Life cycle for a simple radial subnetwork with one controller
      // This routine demonstrates the life cycle of a simple radial subnetwork with one controller
      static void RadialNetworkLifecycle(SubnetworkManager subnetworkManager, Tier mediumVoltageTier, Element elementR1)
        // Create a subnetwork named "Radial1" with a single controller
        // elementR1 represents the device that serves as the subnetwork controller (e.g., circuit breaker)
        Subnetwork subnetworkRadial1 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR1,
          "Radial1", "R1", "my description", "my notes");
        // Update the subnetwork and refresh the map
        subnetworkRadial1.Update();
        MapView.Active.Redraw(true);
        // At some point, a subnetwork will need to be deleted.
        // First step is to disable the controller
        subnetworkManager.DisableControllerInEditOperation(elementR1);
        // At this point, the subnetwork is deleted, but all of the rows that have been labeled with the subnetwork ID need to be updated
        // The final step is to notify external systems (if any) by exporting the subnetwork
        SubnetworkExportOptions subnetworkExportOptions = new SubnetworkExportOptions()
          SetAcknowledged = true,
          IncludeDomainDescriptions = true,
          IncludeGeometry = true,
          ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
          SubnetworkExportResultTypes = new List<SubnetworkExportResultType>()
            SubnetworkExportResultType.Features
          // Set networks attributes and attribute fields to export
          //ResultNetworkAttributes = new List<NetworkAttribute>(networkAttributes),
          //ResultFieldsByNetworkSourceID = new Dictionary<int, List<string>>()
          //  { { electricDevice.ID, new List<string>() { "AssetID" } } }
        subnetworkRadial1.Export(new Uri($"{Path.GetTempPath()}SubnetworkExportResult.json"),
          subnetworkExportOptions);
    Life cycle for a mesh subnetwork with multiple controllers
      // This routine demonstrates the life cycle of a mesh subnetwork with multiple controllers
      static void MeshNetworkLifeCycle(SubnetworkManager subnetworkManager, Tier lowVoltageMeshTier,
      Element elementM1, Element elementM2, Element elementM3)
        // Create a subnetwork named "Mesh1" from three controllers
        // elementM1, elementM2, and elementM3 represent the devices that serve as subnetwork controllers (e.g., network protectors)
        subnetworkManager.EnableController(lowVoltageMeshTier, elementM1, "Mesh1", "M1", "my description", "my notes");
        subnetworkManager.EnableController(lowVoltageMeshTier, elementM2, "Mesh1", "M2", "my description", "my notes");
        Subnetwork subnetworkMesh1 = subnetworkManager.EnableController(lowVoltageMeshTier, elementM3, "Mesh1", "M3",
        subnetworkMesh1.Update();
        // When deleting the subnetwork, each controller must be disabled before the subnetwork itself is deleted
        subnetworkManager.DisableControllerInEditOperation(elementM1);
        subnetworkManager.DisableControllerInEditOperation(elementM2);
        subnetworkManager.DisableControllerInEditOperation(elementM3);
        // After the subnetwork is deleted, all of the rows that have been labeled with the subnetwork ID need to be updated
        subnetworkMesh1.Export(new Uri($"{Path.GetTempPath()}SubnetworkExportResult.json"), subnetworkExportOptions);
    Life cycle for a multifeed radial subnetwork with two controllers
      // This routine demonstrates the life cycle of a multifeed radial subnetwork with two controllers
      static void MultifeedRadialLifeCycle(SubnetworkManager subnetworkManager, Tier mediumVoltageTier, Element elementR2, Element elementR3)
        // Create a subnetwork named "R2, R3" from two controllers
        // elementR2 and elementR3 represent the devices that serve as subnetwork controllers (e.g., circuit breakers)
        subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR2, "R2, R3", "R2",
        subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR3, "R2, R3", "R3",
        // If the tie switch between them is opened, the original subnetwork controllers must be disabled and re-enabled with different names
        // This will create two new subnetworks, named "R2" and "R3"
        subnetworkManager.DisableControllerInEditOperation(elementR2);
        subnetworkManager.DisableControllerInEditOperation(elementR3);
        Subnetwork subnetworkR2 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR2, "R2",
          "R2", "my description", "my notes");
        Subnetwork subnetworkR3 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR3, "R3",
          "R3", "my description", "my notes");
        subnetworkR2.Update();
        subnetworkR3.Update();
    Requirements
