ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetworkExtensions Class / ValidateNetworkTopologyInEditOperation Method / ValidateNetworkTopologyInEditOperation(UtilityNetwork,Geometry) Method
The UtilityNetwork instance whose network topology to validate.
The extent of the area to be validating. If this parameter is missing or null, the entire extent of the utility network is used.
    Validates the utility network topology in an edit operation. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Shared Function ValidateNetworkTopologyInEditOperation( _
       ByVal utilityNetwork As UtilityNetwork, _
       ByVal extent As Geometry _
    ) As ValidationResult
    public static ValidationResult ValidateNetworkTopologyInEditOperation(
       UtilityNetwork utilityNetwork,
       Geometry extent
    Parameters
    utilityNetwork
    extent
    Return Value
    A ValidationResult that describes the result of the operation.
    Exceptions
    ExceptionDescription
    The active ArcGIS.Desktop.Mapping.MapView is unavailable.
    -or-
    The ArcGIS.Desktop.Mapping.UtilityNetworkLayer is unavailable.
    A geodatabase-related exception has occurred.
    Remarks
    • This routine creates its own edit operation, and can therefore not be called within an existing transaction.
    • If this operation is successful, it will create an edit operation on the Pro undo/redo stack, invalidate the affected layers and cause the ArcGIS.Desktop.Mapping.MapView to redraw. When writing a CoreHost application, use UtilityNetwork.ValidateNetworkTopology.
    • This method defaults to ArcGIS.Core.Data.ServiceSynchronizationType.Synchronous.
    Requirements
