ArcGIS.Desktop.Mapping Namespace / ParcelFabricExtensions Class / GetParcelFeaturesAsync Method
The parcel layer.
The source layers and feature IDs of parcel polygon features.
Example
    Gets the other related parcel features for the input parcels.
    Syntax
    Public Shared Function GetParcelFeaturesAsync( _
       ByVal parcelLayer As ParcelLayer, _
       ByVal parcelPolygonFeatures As SelectionSet _
    ) As Task(Of ParcelFeatures)
    Parameters
    parcelLayer
    The parcel layer.
    Return Value
    Exceptions
    ExceptionDescription
    Insufficient license. This method requires a standard license.
    Limit of 1000 input parcels exceeded.
    Example
    Get parcel features
      string sReportResult = "Polygon Information --" + Environment.NewLine;
      string sParcelTypeName = "tax";
      string errorMessage = await QueuedTask.Run(async () =>
        var myParcelFabricLayer =
          MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
        //if there is no fabric in the map then bail
        if (myParcelFabricLayer == null)
          return "There is no fabric layer in the map.";
        //first get the parcel type feature layer
        var featSrcLyr = myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(sParcelTypeName).Result.FirstOrDefault();
        if (featSrcLyr.SelectionCount == 0)
          return "There is no selection on the " + sParcelTypeName + " layer.";
        sReportResult += " Parcel Type: " + sParcelTypeName + Environment.NewLine;
        sReportResult += " Poygons: " + featSrcLyr.SelectionCount + Environment.NewLine + Environment.NewLine;
        try
          // ------- get the selected parcels ---------
          var ids = new List<long>((featSrcLyr as FeatureLayer).GetSelection().GetObjectIDs());
          var sourceParcels = new Dictionary<MapMember, List<long>>
            { featSrcLyr, ids }
          ParcelFeatures parcFeatures =
                          await myParcelFabricLayer.GetParcelFeaturesAsync(SelectionSet.FromDictionary(sourceParcels));
          //since we know that we want to report on Tax lines only, and for this functionality
          // we can use any of the Tax line layer instances (if there happens to be more than one)
          // we can get the first instance as follows
          FeatureLayer myLineFeatureLyr =
              myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(sParcelTypeName).Result.FirstOrDefault();
          if (myLineFeatureLyr == null)
            return sParcelTypeName + " line layer not found";
          FeatureLayer myPointFeatureLyr =
              myParcelFabricLayer.GetPointsLayerAsync().Result.FirstOrDefault();
          if (myPointFeatureLyr == null)
            return "fabric point layer not found";
          var LineInfo = parcFeatures.Lines; //then get the line information from the parcel features object
                                             //... and then do some work for each of the lines
          int iRadiusAttributeCnt = 0;
          int iDistanceAttributeCnt = 0;
          sReportResult += "Line Information --";
          foreach (KeyValuePair<string, List<long>> kvp in LineInfo)
            if (!kvp.Key.Equals(sParcelTypeName, StringComparison.CurrentCultureIgnoreCase))
              continue; // ignore any other lines from different parcel types
            foreach (long oid in kvp.Value)
              var insp = myLineFeatureLyr.Inspect(oid);
              var dRadius = insp["RADIUS"];
              var dDistance = insp["DISTANCE"];
              if (dRadius != DBNull.Value)
                iRadiusAttributeCnt++;
              if (dDistance != DBNull.Value)
                iDistanceAttributeCnt++;
              //Polyline poly = (Polyline)insp["SHAPE"];
            sReportResult += Environment.NewLine + " Distance attributes: " + iDistanceAttributeCnt.ToString();
            sReportResult += Environment.NewLine + " Radius attributes: " + iRadiusAttributeCnt.ToString();
          var PointInfo = parcFeatures.Points; //get the point information from the parcel features object
                                               //... and then do some work for each of the points
          sReportResult += Environment.NewLine + Environment.NewLine + "Point Information --";
          int iFixedPointCnt = 0;
          int iNonFixedPointCnt = 0;
          foreach (long oid in PointInfo)
            var insp = myPointFeatureLyr.Inspect(oid);
            var isFixed = insp["ISFIXED"];
            if (isFixed == DBNull.Value || (int)isFixed == 0)
              iNonFixedPointCnt++;
            else
              iFixedPointCnt++;
            // var pt = insp["SHAPE"];
          sReportResult += Environment.NewLine + " Fixed Points: " + iFixedPointCnt.ToString();
          sReportResult += Environment.NewLine + " Non-Fixed Points: " + iNonFixedPointCnt.ToString();
        catch (Exception ex)
          return ex.Message;
        return "";
      if (!string.IsNullOrEmpty(errorMessage))
        MessageBox.Show(errorMessage, "Get Parcel Features");
      else
        MessageBox.Show(sReportResult, "Get Parcel Features");
    Requirements
