ArcGIS.Desktop.Layouts Namespace / GraphicFactory Class / CreatePredefinedShapeGraphic Method
    CreatePredefinedShapeGraphic Method (GraphicFactory)
    Overload List
    OverloadDescription
    Create a polygon graphic of the specified PredefinedShape using the provided extent and size dimension(s), and symbol. This method must be called on the MCT. Use QueuedTask.Run.
    Create a polygon graphic of the specified PredefinedShape using the provided bounds and symbol. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
