ArcGIS.Desktop.Layouts Namespace / GraphicFactory Class / CreatePredefinedShapeGraphic Method / CreatePredefinedShapeGraphic(PredefinedShape,MapPoint,Double,Double,CIMPolygonSymbol) Method
The shape type of the graphic
The location of the graphic
The width of the graphic bounding box (required)
The height of the graphic bounding box (optional)
The symbol to be used with the graphic (optional)
    Create a polygon graphic of the specified PredefinedShape using the provided extent and size dimension(s), and symbol. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreatePredefinedShapeGraphic( _
       ByVal shapeType As PredefinedShape, _
       ByVal location As MapPoint, _
       ByVal width As Double, _
       Optional ByVal height As Double, _
       Optional ByVal polySymbol As CIMPolygonSymbol _
    ) As CIMPolygonGraphic
    Parameters
    shapeType
    location
    width
    height
    polySymbol
    Exceptions
    ExceptionDescription
    empty or null geometry
    width does not exceed the minimum value
    Remarks
    As a minimum, a width must be provided. If a height is not provided it will be assumed to be the same as the width. Negative width or height values will be treated the same as if they were missing. When generating a circle (i.e. PredefinedShape.Circle) width is used as the circle diameter and height will be ignored. When generating a semicircle or "half-circle" (i.e. PredefinedShape.HalfCircle), if a height is not provided, then it is set to be half the width. When generating an ellipse (i.e. PredefinedShape.Ellipse) width and height are assumed to be the length of the two axis - major/minor depending on which dimension is the longest. For PredefinedShape.RoundedRectangle, a default corner rounding of 20% will be applied.
    Requirements
