ArcGIS.Desktop.Layouts Namespace / IElementFactory Interface / CreateMapSurroundElement Method
The parent element container
The map surround frame envelope or center point
Associated surround properties
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
    CreateMapSurroundElement Method (IElementFactory)
    Create a map surround element based on the geometry and associated map surround and element properties. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    elementContainer
    frameOrLocation
    surroundInfo
    elementName
    select
    elementInfo
    Return Value
    Exceptions
    ExceptionDescription
    Empty or null geometry
    Value cannot be null: surroundInfo
    frameOrLocation must be a point or envelope
    elementContainer must be a layout or group element (on a layout)
    Remarks
    Graphic layers are not valid containers for surrounds. The frameOrLocation can be either a ArcGIS.Core.Geometry.MapPoint or ArcGIS.Core.Geometry.Envelope. A default extent will be calculated if a map point is provided (rather than an envelope).
    Requirements
