ArcGIS.Desktop.Mapping Namespace / Map Class / FindElevationSurfaceLayer Method
The URI of the layer. Which is unique identifier for each layer
Example
    Finds an elevation surface layer using a URI.
    Syntax
    public ElevationSurfaceLayer FindElevationSurfaceLayer(
       string layerURI
    Public Function FindElevationSurfaceLayer( _
       ByVal layerURI As String _
    ) As ElevationSurfaceLayer
    Parameters
    layerURI
    Return Value
    Example
    Find an elevation surface layer
      // retrieve the elevation surface layers in the map
      var surfaceLayers = map.GetElevationSurfaceLayers();
      // find a specific elevation surface layer by its URI
      var surfaceLayer = surfaceLayers.FirstOrDefault(l => l.Name == "Surface2");
      // or use the FindElevationSurfaceLayer method, passing the layer URI
      surfaceLayer = map.FindElevationSurfaceLayer("layerUri");
    Requirements
