ArcGIS.Desktop.Mapping Namespace / Map Class / MoveLayer Method / MoveLayer(Layer,Int32) Method
A layer.
The position specified by the 0-based index. -1 will move the layer the bottom of the map. If the index is invalid, the layer is moved to the bottom.
    Moves a layer to a different position in the table of contents. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void MoveLayer(
       Layer layer,
       int position
    Public Overloads Sub MoveLayer( _
       ByVal layer As Layer, _
       ByVal position As Integer _
    Parameters
    layer
    A layer.
    position
    Exceptions
    ExceptionDescription
    The layer is null.
    Requirements
