ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomToAsync Method / ZoomToAsync(SelectionSet,Nullable<TimeSpan>,Boolean) Method
The collection of layers and corresponding Object IDs in which to zoom.
The amount of time to navigate the view to the new camera position. If null it uses the transition time property set for the application.
Indicates if the Pitch and Heading should remain the same after the navigation is completed. If false the Heading will be set to 15.0 and the Pitch will be set to -60.0. This parameter only effects 3D views.
    Zoom the view to the extent of one or more features.
    Syntax
    Public Overloads Function ZoomToAsync( _
       ByVal features As SelectionSet, _
       Optional ByVal duration As Nullable(Of TimeSpan), _
       Optional ByVal maintainViewDirection As Boolean _
    ) As Task(Of Boolean)
    Parameters
    features
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Requirements
