ArcGIS.Desktop.Mapping Namespace / StandaloneTableFactory Class / CreateStandaloneTable Method / CreateStandaloneTable(Uri,IStandaloneTableContainerEdit,Int32,String) Method
An URI represents the path to a dataset
A map or group layer where the StandaloneTable will be added
The position of the StandaloneTable in the map or group layer. 0 represents the top most position.
System.String (optional) When not provided, the default display name gets used e.g. the dataset name or alias. (default value = "")
Example
    Creates a new StandaloneTable instance with the specified path to a dataset and adds it to a container such as a map. Optionally you can provide a name to override the default display name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateStandaloneTable( _
       ByVal tableUri As Uri, _
       ByVal container As IStandaloneTableContainerEdit, _
       Optional ByVal index As Integer, _
       Optional ByVal tableName As String _
    ) As StandaloneTable
    Parameters
    tableUri
    container
    index
    tableName
    Return Value
    Exceptions
    ExceptionDescription
    TableUri or container is null
    Remarks
    Some sample paths to:
    A table in a FileGeodatabase C:\Data\MyFileGDB.gdb\MyNonSpatialTable
    A dbf file in a folder \\Machine\SharedFolder\MyNonSpatial.dbf
    Example
    Create a StandaloneTable
        //container can be a map or group layer
        var container = MapView.Active.Map;
        //var container =  MapView.Active.Map.GetLayersAsFlattenedList()
        //                                  .OfType<GroupLayer>().First();
        //Note: Run within a QueuedTask
        //use a local path
        var table = StandaloneTableFactory.Instance.CreateStandaloneTable(
            new Uri(@"C:\Temp\Data\SDK.gdb\EarthquakeDamage", UriKind.Absolute), container);
        //use a URI to a feature service table endpoint
        var table2 = StandaloneTableFactory.Instance.CreateStandaloneTable(
                      new Uri(@"https://bexdog.esri.com/server/rest/services/FeatureServer" + "/2", UriKind.Absolute), container);
        //Use an item
        var item = ItemFactory.Instance.Create(@"C:\Temp\Data\SDK.gdb\ParcelOwners");
        var tableCreationParams = new StandaloneTableCreationParams(item);
        var table3 = StandaloneTableFactory.Instance.CreateStandaloneTable(tableCreationParams, container);
        //use table creation params
        var table_params = new StandaloneTableCreationParams(item)
            DefinitionQuery = new DefinitionQuery(whereClause: "LAND_USE = 3", name: "Landuse")
        var table4 = StandaloneTableFactory.Instance.CreateStandaloneTable(table_params, container);
    Requirements
