ArcGIS.Desktop.Mapping Namespace / ILayerFactory Interface / CreateLayer Method / CreateLayer<T>(LayerCreationParams,ILayerContainerEdit) Method
Expected Layer Type
Can be one of LayerCreationParams derived objects.
A map or group layer instance to which the Layer will be added.
Example
    Creates a new Layer instance using the specified LayerCreationParams and adds that to a container such as a map or group layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function CreateLayer(Of T As Layer)( _
       ByVal layerParams As LayerCreationParams, _
       ByVal container As ILayerContainerEdit _
    ) As T
    Parameters
    layerParams
    container
    Type Parameters
    T
    Expected Layer Type
    Return Value
    A specific Layer instance corresponding to type T.
    Exceptions
    ExceptionDescription
    LayerCreationParams or container is null.
    Cannot create the layer of the specified type with the set of LayerCreationParams.
    Example
    Create a KG Layer containing a subset of Entity and Relate types
      await QueuedTask.Run(() =>
        //To create a KG layer (on a map or link chart) with a subset of
        //entities and relates, you must create an "id set". The workflow
        //is very similar to how you would create a SelectionSet.
        //First, create a dictionary containing the names of the types to be
        //added plus a corresponding list of ids (just like with a selection set).
        //Note: null or an empty list means add all records for "that" type..
        var kg_datamodel = kg.GetDataModel();
        //Arbitrarily get the name of the first entity and relate type
        var first_entity = kg_datamodel.GetEntityTypes().Keys.First();
        var first_relate = kg_datamodel.GetRelationshipTypes().Keys.First();
        //Make entries in the dictionary for each
        var dict = new Dictionary<string, List<long>>();
        dict.Add(first_entity, new List<long>());//Empty list means all records
        dict.Add(first_relate, null);//null list means all records
                                     //or specific records - however the ids are obtained
                                     //dict.Add(entity_or_relate_name, new List<long>() { 1, 5, 18, 36, 78});
        //Create the id set...
        var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict);
        //Create the layer params and assign the id set
        var kg_params = new KnowledgeGraphLayerCreationParams(kg)
          Name = "KG_With_ID_Set",
          IsVisible = false,
          IDSet = idSet
        //Call layer factory with map or group layer container
        //A KG layer containing just the feature layer(s) and/or standalone table(s)
        //for the entity and/or relate types + associated records will be created
        var kg_layer = LayerFactory.Instance.CreateLayer<KnowledgeGraphLayer>(
            kg_params, map);
    Create layer with create-params
      var flyrCreatnParam = new FeatureLayerCreationParams(new Uri(@"c:\data\world.gdb\cities"))
        Name = "World Cities",
        IsVisible = false,
        MinimumScale = 1000000,
        MaximumScale = 5000,
        DefinitionQuery = new DefinitionQuery(whereClause: "Population > 100000", name: "More than 100k"),
        RendererDefinition = new SimpleRendererDefinition()
          SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
         CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
      var featureLayerWithParams = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<FeatureLayer>(flyrCreatnParam, map));
    Create FeatureLayer and add to Map using LayerCreationParams
      //Get the LayerDocument from a lyrx file
      var layerDoc = new LayerDocument(@"E:\Data\SDK\Default2DPointSymbols.lyrx");
      //Get the CIMLayerDocument from the LayerDocument and use it to create LayerCreationParams
      var createParams = new LayerCreationParams(layerDoc.GetCIMLayerDocument());
      //Create a FeatureLayer using the LayerCreationParams
      await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer<FeatureLayer>(createParams, map));
    Create FeatureLayer and set to not display in Map.
      //The catalog path of the feature layer to add to the map
      var featureClassUriVisibility = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
      //Define the Feature Layer's parameters.
      var layerParamsVisibility = new FeatureLayerCreationParams(featureClassUriVisibility)
        //Set visibility
        IsVisible = false,
      //Create the layer with the feature layer parameters and add it to the active map
      var createdFC = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsVisibility, map));
    Create FeatureLayer with a Renderer
      //Define a simple renderer to draw the Point US Cities feature class.
      var simpleRender = new SimpleRendererDefinition
        SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 4.0, SimpleMarkerStyle.Circle).MakeSymbolReference()
      var featureClassUri = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
      var layerParams = new FeatureLayerCreationParams(featureClassUri)
        //Set visibility
        IsVisible = true,
        //Set Renderer
        RendererDefinition = simpleRender,
      var createdFCWithRenderer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, map));
    Create FeatureLayer with a Query Definition
      var featureClassUriDefinition = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
      var layerParamsQueryDefn = new FeatureLayerCreationParams(featureClassUriDefinition)
        IsVisible = true,
        DefinitionQuery = new DefinitionQuery(whereClause: "STATE_NAME = 'California'", name: "CACities")
      var createdFCWithQueryDefn = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsQueryDefn, map));
    Create TopologyLayer with an Uri pointing to a Topology dataset
      var path = @"D:\Data\CommunitySamplesData\Topology\GrandTeton.gdb\BackCountry\Backcountry_Topology";
      var lcp = new TopologyLayerCreationParams(new Uri(path));
      lcp.Name = "GrandTeton_Backcountry";
      lcp.AddAssociatedLayers = true;
      var topoLayer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.TopologyLayer>(lcp, map));
    Create Topology Layer using Topology dataset
      //Get the Topology of another Topology layer
      var existingTopology = map.GetLayersAsFlattenedList().OfType<TopologyLayer>().FirstOrDefault();
      if (existingTopology != null)
          var topology = existingTopology.GetTopology();
          //Configure the settings for a new Catalog layer using the CatalogDataset of an existing layer
          var topologyLyrParams = new TopologyLayerCreationParams(topology);
          topologyLyrParams.Name = "NewTopologyLayerFromAnotherTopologyLayer";
          topologyLyrParams.AddAssociatedLayers = true;
          LayerFactory.Instance.CreateLayer<TopologyLayer>(topologyLyrParams, map);
    Create Catalog Layer using Uri to a Catalog Feature Class
      var createParams = new CatalogLayerCreationParams(new Uri(@"C:\CatalogLayer\CatalogDS.gdb\HurricaneCatalogDS"));
      //Set the definition query
      createParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'PuertoRico'");
      //Set name of the new Catalog Layer
      createParams.Name = "PuertoRico";
      //Create Layer
      var catalogLayer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<CatalogLayer>(createParams, map));
    Create Catalog Layer using CatalogDataset
      //Get the CatalogDataset of another Catalog layer
      var existingCatalogLayer = map.GetLayersAsFlattenedList().OfType<CatalogLayer>().FirstOrDefault();
      if (existingCatalogLayer != null)
          var catalogDataset = existingCatalogLayer.GetCatalogDataset();
          var catalogLyrParams = new CatalogLayerCreationParams(catalogDataset);
          catalogLyrParams.Name = "NewCatalogLayerFromAnotherCatalogLayer";
          catalogLyrParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'Asia'");
          LayerFactory.Instance.CreateLayer<CatalogLayer>(catalogLyrParams, map);
    Add MapNotes to the active map
      //Gets the collection of layer template packages installed with Pro for use with maps
      var items = map.LayerTemplatePackages;
      //Iterate through the collection of items to add each Map Note to the active map
      foreach (var item in items)
        //Create a parameter item for the map note
        var layer_params = new LayerCreationParams(item);
        layer_params.IsVisible = false;
        //Create a feature layer for the map note
        var layerCreated = await QueuedTask.Run(() =>
          LayerFactory.Instance.CreateLayer<Layer>(layer_params, map));
    Apply Symbology from a Layer in the TOC
        if (map == null)
          return;
      //Get an existing Layer. This layer has a symbol you want to use in a new layer.
      var lyr = map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
            .Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint).FirstOrDefault();
      //This is the renderer to use in the new Layer
      var renderer = lyr.GetRenderer() as CIMSimpleRenderer;
      //Set the DataConnection for the new layer
      Geodatabase geodatabase = new Geodatabase(
        new FileGeodatabaseConnectionPath(new Uri(@"E:\Data\Admin\AdminData.gdb")));
      FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("Cities");
      var dataConnection = featureClass.GetDataConnection();
      //Create the definition for the new feature layer
      var featureLayerParams = new FeatureLayerCreationParams(dataConnection)
        RendererDefinition = new SimpleRendererDefinition(renderer.Symbol),
        IsVisible = true,
      //create the new layer
          featureLayerParams, map);
    Create a new SubTypeGroupLayer
      var subtypeGroupLayerCreateParam = new SubtypeGroupLayerCreationParams
        (new Uri(@"c:\data\SubtypeAndDomain.gdb\Fittings"));
      // Define Subtype layers
      var rendererDefn1 = new UniqueValueRendererDefinition(new List<string> { "type" });
      var renderDefn2 = new SimpleRendererDefinition()
      subtypeGroupLayerCreateParam.SubtypeLayers = new List<SubtypeFeatureLayerCreationParams>()
          //define first subtype layer with unique value renderer
          new SubtypeFeatureLayerCreationParams(new UniqueValueRendererDefinition(new List<string> { "type" }), 1),
          //define second subtype layer with simple symbol renderer
          new SubtypeFeatureLayerCreationParams(renderDefn2, 2)
      // Define additional parameters
      subtypeGroupLayerCreateParam.DefinitionQuery = new DefinitionQuery(whereClause: "Enabled = 1", name: "IsActive");
      subtypeGroupLayerCreateParam.IsVisible = true;
      subtypeGroupLayerCreateParam.MinimumScale = 50000;
      SubtypeGroupLayer subtypeGroupLayer2 = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<SubtypeGroupLayer>(subtypeGroupLayerCreateParam, map));
    Create layer from a lyrx file
        var lyrDocFromLyrxFile = new LayerDocument(@"d:\data\cities.lyrx");
        var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
      //modifying its renderer symbol to red
      var cimSimpleRenderer = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMSimpleRenderer;
      cimSimpleRenderer?.Symbol.Symbol.SetColor(new CIMRGBColor() { R = 255 });
      //optionally save the updates out as a file
      lyrDocFromLyrxFile.Save(@"c:\data\cities_red.lyrx");
      //get a json representation of the layer document and you want store away...
      var aJSONString = lyrDocFromLyrxFile.AsJson();
      //... and load it back when needed
      lyrDocFromLyrxFile.Load(aJSONString);
      //create a layer and add it to a map
        var lcp = new LayerCreationParams(cimLyrDoc);
        var lyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
    Add a WMS service
      // Create a connection to the WMS server
      var serverConnection = new CIMInternetServerConnection { URL = "URL of the WMS service" };
      var connection = new CIMWMSServiceConnection { ServerConnection = serverConnection };
      // Add a new layer to the map
      var layerParams = new LayerCreationParams(connection);
    Add a WFS Service
      CIMStandardDataConnection cIMStandardDataConnection = new CIMStandardDataConnection()
        WorkspaceConnectionString = @"SWAPXY=TRUE;SWAPXYFILTER=FALSE;URL=http://sampleserver6.arcgisonline.com/arcgis/services/SampleWorldCities/MapServer/WFSServer;VERSION=2.0.0",
        WorkspaceFactory = WorkspaceFactory.WFS,
        Dataset = "Continent",
        DatasetType = esriDatasetType.esriDTFeatureClass
      var layerPamsDC = new LayerCreationParams(cIMStandardDataConnection);
      Layer layerCreated = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<FeatureLayer>(layerPamsDC, map));
    Add a WMTS service
      var serverConnection = new CIMProjectServerConnection
        URL = "URL of the WMTS service.xml",
        ServerType = ServerType.WMTS,
      var service_connection = new CIMWMTSServiceConnection
        ServerConnection = serverConnection,
        LayerName = "AdminBoundaries", // Specify the layer name you want to add
      var layerParams = new LayerCreationParams(service_connection);
      layerParams.MapMemberPosition = MapMemberPosition.AddToBottom;
    Connect to an AGS Service using a .ags File
      //This workflow would work for
      var agsFilePath = @"C:\Data\ServerConnectionFiles\AcmeSampleService.ags";
      //ServerConnectionProjectItem supports .ags, .wms, .wmts, .wfs, and .wcs files
      var server_conn_item = ItemFactory.Instance.Create(agsFilePath)
        as ArcGIS.Desktop.Catalog.ServerConnectionProjectItem;
      //Get the server connection - passwords are never returned
      var serverConnection = server_conn_item.ServerConnection as CIMProjectServerConnection;
      //Add to an AGS service connection
      var service_connection = new CIMAGSServiceConnection()
        URL = "URL to the AGS _service_ on the AGS _server_",
    Connect to an AGS Service using ServiceConnectionProperties
      //Connect to the AGS service. Note: the connection will persist for the
      //duration of the Pro session.
      var serverUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services";
      var username = "user1";
      var password = "user1";
      //at any point before creating a layer, first make a connection to the server
      //if one has not been already established for the current session
      var uri = new Uri(serverUrl);
      var props = new ServiceConnectionProperties(uri)
        User = username
      //It is preferred that you use the Windows Credential Manager to store the password
      //However, it can be set as clear text if you so choose
      props.Password = password; //not recommended
      //Establish a connection to the server at any point in time _before_
      //creating a layer from a service on the server
        using var gdb = new Geodatabase(props);
      //later in the session, as needed...create a layer from one of the services
      //on the server
      var serviceUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire_secure/MapServer";
      var lc = new LayerCreationParams(new Uri(serviceUrl));
      await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer<MapImageLayer>(lc, map));
    Adding and changing styles for WMS Service Layer
      var serverConnection = new CIMInternetServerConnection { URL = "https://spritle.esri.com/arcgis/services/sanfrancisco_sld/MapServer/WMSServer" };
      LayerCreationParams parameters = new LayerCreationParams(connection);
      parameters.MapMemberPosition = MapMemberPosition.AddToBottom;
        var compositeLyr = LayerFactory.Instance.CreateLayer<WMSLayer>(parameters, map);
        //wms layer in ArcGIS Pro always has a composite layer inside it
        var wmsLayers = compositeLyr.Layers[0] as ServiceCompositeSubLayer;
        //each wms sublayer belongs in that composite layer
        var highwayLayerWMSSub = wmsLayers.Layers[1] as WMSSubLayer;
        //toggling a sublayer's visibility
        if ((highwayLayerWMSSub != null))
          bool visibility = highwayLayerWMSSub.IsVisible;
          highwayLayerWMSSub.SetVisibility(!visibility);
        //applying an existing style to a wms sub layer
        var pizzaLayerWMSSub = wmsLayers.Layers[0] as WMSSubLayer;
        var currentStyles = pizzaLayerWMSSub.GetStyleNames();
        pizzaLayerWMSSub.SetStyleName(currentStyles[1]);
    Create a query layer
      Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri(@"C:\Connections\mySDE.sde")));
      CIMSqlQueryDataConnection sqldc = new CIMSqlQueryDataConnection()
        WorkspaceConnectionString = geodatabase.GetConnectionString(),
        GeometryType = esriGeometryType.esriGeometryPolygon,
        OIDFields = "OBJECTID",
        Srid = "102008",
        SqlQuery = "select * from MySDE.dbo.STATES",
        Dataset = "States"
      var lcp = new LayerCreationParams(sqldc)
        Name = "States"
      FeatureLayer flyr = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map));
    Create a feature layer with class breaks renderer with defaults
      var featureLayerCreationParams = new FeatureLayerCreationParams(new Uri(@"c:\data\countydata.gdb\counties"))
        Name = "Population Density (sq mi) Year 2010",
        RendererDefinition = new GraduatedColorsRendererDefinition("POP10_SQMI")
        featureLayerCreationParams, map));
    Create a New Elevation Surface
      //Define a ServiceConnection to use for the new Elevation surface
        Anonymous = true,
        HideUserProperty = true,
        URL = "https://elevation.arcgis.com/arcgis/services"
      CIMAGSServiceConnection serviceConnection = new CIMAGSServiceConnection
        ObjectName = "WorldElevation/Terrain",
        ObjectType = "ImageServer",
        URL = "https://elevation.arcgis.com/arcgis/services/WorldElevation/Terrain/ImageServer",
      //Defines a new elevation source set to the CIMAGSServiceConnection defined above
      //Get the elevation surfaces defined in the map
      var listOfElevationSurfaces = map.GetElevationSurfaceLayers();
      //Add the new elevation surface
      var elevationLyrCreationParams = new ElevationLayerCreationParams(serviceConnection);
      var elevationSurface = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<ElevationSurfaceLayer>(elevationLyrCreationParams, map));
    Add an elevation source to an existing elevation surface layer
      ElevationSurfaceLayer surfaceLayer = null;
      // surfaceLayer could also be the ground layer
      string uri = "https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer";
      var createParams = new ElevationLayerCreationParams(new Uri(uri));
      createParams.Name = "Terrain 3D";
      var eleSourceLayer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<Layer>(createParams, surfaceLayer));
    Create a raster layer with a new colorizer definition
      // Create a new stretch colorizer definition using default constructor.
      StretchColorizerDefinition stretchColorizerDef = new StretchColorizerDefinition();
      // Create a raster layer creation parameters object with the raster file path.
      var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("rasterPath"))
        ColorizerDefinition = stretchColorizerDef,
        Name = "rasterLayerName",
        MapMemberIndex = 0
      // Create a raster layer using the colorizer definition created above.
      // Note: You can create a raster layer from a url, project item, or data connection.
      RasterLayer rasterLayerfromURL = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<RasterLayer>(rasterLayerCreationParams, map));
    Create a mosaic layer with a new colorizer definition
    // Create a new colorizer definition using default constructor.
      var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("url"))
        Name = "layerRasterName",
        MapMemberIndex = 0
      // Create a mosaic layer using the colorizer definition created above.
      // Note: You can create a mosaic layer from a url, project item, or data connection.
      MosaicLayer newMosaicLayer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<MosaicLayer>(rasterLayerCreationParams, map));
    Create an image service layer with a new colorizer definition
      var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri(url))
        Name = "RasterLayer",
        MapMemberIndex = 0
      // Create an image service layer using the colorizer definition created above.
      ImageServiceLayer imageServiceLayerWithColorizer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<ImageServiceLayer>(rasterLayerCreationParams, map));
    EsriHttpClient: Get a Service Layer and Add it to Pro
      UriBuilder searchURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
        Path = "sharing/rest/search"
      string layers = "(type:\"Map Service\" OR type:\"Image Service\" OR type:\"Feature Service\" OR type:\"WMS\" OR type:\"KML\")";
      //any public layer content
      searchURL.Query = string.Format("q={0}&f=json", layers);
      EsriHttpClient httpClient = new EsriHttpClient();
      var searchResponse = httpClient.Get(searchURL.Uri.ToString());
      dynamic resultItems = JObject.Parse(await searchResponse.Content.ReadAsStringAsync());
      long numberOfTotalItems = resultItems.total.Value;
      if (numberOfTotalItems == 0)
        return;
      List<dynamic> resultItemList = new List<dynamic>();
      resultItemList.AddRange(resultItems.results);
      //get the first result
      dynamic item = resultItemList[0];
      string itemID = item.id;
      Item currentItem = ItemFactory.Instance.Create(itemID, ItemFactory.ItemType.PortalItem);
      var mapView = MapView.Active;
      if (mapView == null)
        return;
        //Create a LayerCreationParam
        var layerParam = new LayerCreationParams(currentItem);
        // if we have an item that can be turned into a layer
        // add it to the map
        if (LayerFactory.Instance.CanCreateLayerFrom(currentItem))
          LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParam, mapView.Map);
    Create a TinLayer
      string tinPath = @"d:\Data\Tin\TinDataset";
      var tinURI = new Uri(tinPath);
      var tinCP = new TinLayerCreationParams(tinURI);
      tinCP.Name = "My TIN Layer";
      tinCP.IsVisible = false;
        //Create the layer to the TIN
        tinLayer = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP, map);
    Create a TinLayer from a dataset
      var tinCP_ds = new TinLayerCreationParams(tinDataset);
      tinCP_ds.Name = "My TIN Layer";
      tinCP_ds.IsVisible = false;
        var tinLayer_ds = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_ds, map);
    Create a TinLayer with renderers
      var tinCP_renderers = new TinLayerCreationParams(tinDataset)
        Name = "My TIN layer",
        IsVisible = true
      // define the node renderer - use defaults
      var node_rd = new TinNodeRendererDefinition();
      // define the face/surface renderer
      var face_rd = new TinFaceClassBreaksRendererDefinition();
      face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // accept default color ramp, breakCount
      // set up the renderer dictionary
      var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
      { SurfaceRendererTarget.Points, node_rd },
      { SurfaceRendererTarget.Surface, face_rd }
      // assign the dictionary to the creation params
      tinCP_renderers.RendererDefinitions = rendererDict;
        // create the layer
        var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, mapView.Map);
    Create a TerrainLayer
        string terrainPath = @"d:\Data\Terrain\filegdb_Containing_A_Terrain.gdb\FeatureDataset\Terrain_name";
        var terrainURI = new Uri(terrainPath);
        var terrainCP = new TerrainLayerCreationParams(terrainURI);
        terrainCP.Name = "My Terrain Layer";
        terrainCP.IsVisible = false;
        //Create the layer to the terrain
        terrainLayer = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP, map);
    Create a TerrainLayer from a dataset
      var terrainCP_ds = new TerrainLayerCreationParams(terrain);
      terrainCP_ds.Name = "My Terrain Layer";
      terrainCP_ds.IsVisible = true;
        var terrainLayer_ds = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_ds, map);
    Create a TerrainLayer with renderers
      var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
      terrainCP_renderers.Name = "My LAS Layer";
      terrainCP_renderers.IsVisible = true;
      // define the edge type renderer - use defaults
      var edgeRD = new TinBreaklineRendererDefinition();
      var faceRD = new TinFaceClassBreaksRendererDefinition();
      faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // define the dirty area renderer - use defaults
      var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
      // add renderers to dictionary
      var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
      t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
      t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
      t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
      // assign dictionary to creation params
      terrainCP_renderers.RendererDefinitions = t_dict;
        var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
    Create a LasDatasetLayer
      string lasPath = @"d:\Data\LASDataset.lasd";
      var lasURI = new Uri(lasPath);
      var lasCP = new LasDatasetLayerCreationParams(lasURI);
      lasCP.Name = "My LAS Layer";
      lasCP.IsVisible = false;
        //Create the layer to the LAS dataset
        lasDatasetLayer = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP, map);
    Create a LasDatasetLayer from a LasDataset
      if (lasDataset == null)
        throw new ArgumentNullException(nameof(lasDataset));
      var lasCP_ds = new LasDatasetLayerCreationParams(lasDataset);
      lasCP_ds.Name = "My LAS Layer";
      lasCP_ds.IsVisible = false;
        var lasDatasetLayer_ds = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_ds, map);
    Create a LasDatasetLayer with renderers
      var lasCP_renderers = new LasDatasetLayerCreationParams(lasDataset);
      lasCP_renderers.Name = "My LAS Layer";
      lasCP_renderers.IsVisible = false;
      // create a point elevation renderer
      var ptR = new LasStretchRendererDefinition();
      // accept all defaults
      // create a simple edge renderer
      var edgeR = new TinEdgeRendererDefintion();
      var l_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
      l_dict.Add(SurfaceRendererTarget.Points, ptR);
      l_dict.Add(SurfaceRendererTarget.Edges, edgeR);
      lasCP_renderers.RendererDefinitions = l_dict;
        var lasDatasetLayer_rd = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_renderers, map);
    Create GraphicsLayer
      if (map.MapType != MapType.Map)
        return;// not 2D
      var gl_param = new GraphicsLayerCreationParams { Name = "Graphics Layer" };
        //By default will be added to the top of the TOC
        graphicsLayer = LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.GraphicsLayer>(gl_param, map);
        //Add to the bottom of the TOC
        gl_param.MapMemberIndex = -1; //bottom
        //Add a graphics layer to a group layer...
        var group_layer = map.GetLayersAsFlattenedList().OfType<GroupLayer>().First();
        LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.GraphicsLayer>(gl_param, group_layer);
        //TODO...use the graphics layer
        // or use the specific CreateGroupLayer method
        LayerFactory.Instance.CreateGroupLayer(map, -1, "Graphics Layer");
    Create a Scene Layer
      var map = MapView.Active?.Map;
      if (map == null)
        return;
        //Create with initial visibility set to false. Add to current scene
        var createparams = new LayerCreationParams(new Uri(sceneLayerUrl, UriKind.Absolute))
          IsVisible = false
        //cast to specific type of scene layer being created - in this case FeatureSceneLayer
        var sceneLayer = LayerFactory.Instance.CreateLayer<Layer>(
                 createparams, map) as FeatureSceneLayer;
        //or...specify the cast directly
        var sceneLayer2 = LayerFactory.Instance.CreateLayer<FeatureSceneLayer>(
                 createparams, map);
        //ditto for BuildingSceneLayer, PointCloudSceneLayer, IntegratedMeshSceneLayer
    Create Stream Layer with URI
        var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
        var createParam = new FeatureLayerCreationParams(new Uri(url))
          IsVisible = false //turned off by default
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(createParam, map);
        //or use "original" create layer (will be visible by default)
        Uri uri = new Uri(url);
        streamLayer = LayerFactory.Instance.CreateLayer(uri, map) as StreamLayer;
        streamLayer.SetVisibility(false);//turn off
    Create a stream layer with a definition query
        var lyrCreateParam = new FeatureLayerCreationParams(new Uri(url))
          IsVisible = true,
          DefinitionQuery = new DefinitionQuery(whereClause: "RWY = '29L'", name: "Runway")
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(lyrCreateParam, map);
    Create a stream layer with a simple renderer
        var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/LABus/StreamServer";
        var uri = new Uri(url, UriKind.Absolute);
        var createParams = new FeatureLayerCreationParams(uri)
                                ColorFactory.Instance.BlueRGB,
                                12,
                         SimpleMarkerStyle.Pushpin).MakeSymbolReference()
                            createParams, map);
    Setting a unique value renderer for latest observations
        var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
          IsVisible = false
                            createParams, map);
        //Define the unique values by hand
        var uvr = new CIMUniqueValueRenderer()
          Fields = new string[] { "ACTYPE" },
          UseDefaultSymbol = true,
          DefaultLabel = "Others",
          DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(
                      CIMColor.CreateRGBColor(185, 185, 185), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        var classes = new List<CIMUniqueValueClass>
          //add in classes - one for ACTYPE of 727, one for DC 9
          new CIMUniqueValueClass()
            Values = new CIMUniqueValue[] {
                    new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
            Visible = true,
            Label = "Boeing 727",
                      ColorFactory.Instance.RedRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
                    new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
            Visible = true,
            Label = "DC 9",
                      ColorFactory.Instance.GreenRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //add the classes to a group
        var groups = new List<CIMUniqueValueGroup>()
        new CIMUniqueValueGroup() {
           Classes = classes.ToArray()
        //add the groups to the renderer
        uvr.Groups = groups.ToArray();
        //Apply the renderer (for current observations)
        streamLayer.SetRenderer(uvr);
        streamLayer.SetVisibility(true);//turn on the layer
    Create Voxel Layer
        //Must be a .NetCDF file for voxels
        var url = @"C:\MyData\AirQuality_Redlands.nc";
        var cim_connection = new CIMVoxelDataConnection()
          URI = url
        //Create a VoxelLayerCreationParams
        var createParams = VoxelLayerCreationParams.Create(cim_connection);
        createParams.IsVisible = true;
        //Can also just use the path directly...
        //var createParams = VoxelLayerCreationParams.Create(url);
        //Use VoxelLayerCreationParams to enumerate the variables within
        //the voxel
        var variables = createParams.Variables;
        foreach (var variable in variables)
          var line = $"{variable.Variable}: {variable.DataType}, " +
             $"{variable.Description}, {variable.IsDefault}, {variable.IsSelected}";
          System.Diagnostics.Debug.WriteLine(line);
        //Optional: set the default variable
        createParams.SetDefaultVariable(variables.Last());
        //Create the layer - map must be a local scene
        voxelLayer = LayerFactory.Instance.CreateLayer<VoxelLayer>(createParams, map);
    Requirements
